Show Printable Version 15 Likes Search this Thread
02-10-2017, 09:18 PM - 1 Like   #16
Not a Number's Avatar
You can buy those super cheap extension tubes they sell on eBay. The ones with only one set of bayonet mounts. Put the female K-mount on one end and leave the male bayonet off to make a lens hood - exposed rear bits cover.
02-10-2017, 09:56 PM   #17
Do you mean these? Which of these would act as a cover?
02-10-2017, 10:15 PM   #18
Take the female mount (on the right, call it A), mount it on the reversed lens. Take one or more of the inner rings (say #2) and screw it on to part A. Done. Leave off the male part (all the way on the left). Less chance of vignetting without it.
02-10-2017, 10:56 PM   #19
Man With A Camera
Racer X 69's Avatar
Location: The Great Pacific Northwet, in the Land Between Canada and Mexico
QuoteOriginally posted by Göran Quote
Not a cover.
A hood.
02-10-2017, 11:15 PM - 1 Like   #20
It would act as a hood with the benefit that the rear bits of the lens would then be recessed and thus have some protection.
If you want a cover just use a rear lens cap. If just want to protect the rear bits use part A or take a rear lens cap and out out the top (or bottom) whatever the case may be
02-10-2017, 11:45 PM   #21
Man With A Camera
Racer X 69's Avatar
My thoughts exactly.
02-11-2017, 01:01 AM - 1 Like   #22
Nass's Avatar
QuoteOriginally posted by Racer X 69 Quote
That's what I do
To go back to the original question, you need a reversing ring that has the same mm as the filter thread of the lens you intend to reverse (as that's what you'll use to mount it). Reversing the 50 onto the 18-135 won't work all that great I think. You really want the main one to be larger than the reversed one - so I think you won't get anything great for the 18-50 part of that zoom. Don't know about the 50-135 range, but small aperture zooms give unpredictable results when used as the main lens on a coupled reverse lens setup, I've had much more luck with primes. I have a site about this sort of thing you might find useful: see http://extreme-macro.co.uk/coupled-reverse-lens/
Good luck!
-Johan
02-12-2017, 10:35 AM   #23
That adapter would probably work as a hood but because m4/3 has a much smaller diameter you may get vignetting. Or maybe not since macro can have a rather narrow field of view.
Here is a used set of the inexpensive screw together type that I mentioned earlier. Not much more than the above adapter.
http://www.ebay.de/itm/Macro-Extension-Tube-Rings-For-Pentax-K-Mount-near-mi...oAAOSwo4pYl3uO
02-12-2017, 01:02 PM   #24
Otis Memorial Pentaxian
Macro Extension Tube Rings For Pentax K Mount near mi oAAOSwo4pYl3uO | eBay
I sort of like those, particularly if auto-aperture actuation is not required.
02-12-2017, 08:52 PM   #25
Just search eBay for "extension tubes Pentax" and you'll find maybe a dozen vendor (mostly in China) selling them.
You can most likely mix and match different sets of camera mounts too.
02-12-2017, 10:46 PM   #26
Man With A Camera
Racer X 69's Avatar
The possibilities are endless, only limited by the imagination of the individual.
02-13-2017, 06:28 AM   #27
Just a quick follow-up: What would be my best way forward, after getting my reverse lens setup going, to get even higher magnification? My initial thought was 1x macro lenses, but I already got 1x magnification(and beyond) with this setup. Would any of you recommend a bellows? Should I open a new topic for this?
I'm asking because, at what point is buying all these accesories more expensive than "just" buying more expensive macro lenses?
Bellows sound promising because I am currently trying focus stacking.
02-13-2017, 08:47 AM - 1 Like   #28
Extreme Macro Photography
02-13-2017, 10:25 AM   #29
I've been visiting that site very frequently, but would like additional input. Also, I asked about forum specific stuff, and this doesn't answer my question.
02-13-2017, 10:50 AM   #30
Man With A Camera
Racer X 69's Avatar
The accessories make the process more doable. To be successful you need good equipment. For instance, a focusing rail for focus stacking. Get a cheap $20 rail setup off of eBay and you will not have good, repeatable results. Spend the cash on a decent rail setup and your success rate will increase dramatically.
And when things work well you will be happier with the results and more likely to try more.
As for 'expensive' macro lenses, well, some of my best lenses for close up photography are older manual lenses, M, A, an Industar 61 50mm f2.8 ($50 from the Ukraine, brand new). I've spent more on the accessories than lenses.
And those lenses get used for other photography work too.
Win win.
50mm, extension, extension tube, help, lens, lens onto extension, macro, question, reverse lens, tube
Trouble Mounting an M42 lens via an M42-K Adapter onto K-mount Bodies fwcetus Pentax SLR Lens Discussion 9 09-19-2015 02:51 PM
Reverse prime lens for macro Michael Piziak Photographic Technique 7 05-18-2014 01:13 PM
Reverse Mounting my 50/1.2 J.Langer Troubleshooting and Beginner Help 13 10-02-2012 11:28 PM
Reverse stacking for macro onto a 100mm macro lens - 28mm good? GibbyTheMole Pentax SLR Lens Discussion 10 04-27-2012 02:56 AM
Reverse Extension Tube sajah Troubleshooting and Beginner Help 3 04-01-2009 06:42 AM
All times are GMT -7. The time now is 11:24 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
