Originally posted by Göran Thanks for the quick reply. I was also thinking of trying using two lenses, but the only other one I have is the 18-135mm Kit lens. I have no idea how it would perform. The step ring I would use there would be a 62mm(from the 18-135mm) to 49mm(from the 50mm), am I correct?
About the lens being exposed: You are talking about protecting it, while it is not in use, correct? Again, thanks for the help!
Not sure how a zoom lens would work with a double lens setup. Also, using newer lenses without aperture rings will make it tough to manage the aperture. You would have to figure out a way to hold the lever that links the diaphragm with the camera to keep it wide open, otherwise the viewfinder will be very dark.
All is not lost though.
Manual lenses can be found at a reasonable cost. Here on the marketplace, eBay, KEH, Craigslist, even second hand stores are all sources available to you.
As for the raw end of a reversed lens, the protection that has been mentioned is for while you are making photographs. When you are done with a photo session you shouldn't be leaving the equipment in the macro set up , but rather break it all down and put everything back, caps, cases, etc.
