My post about which lens to stop down seems to have gotten lost, so I'll repost and hope I'm not duplicating.
The author of the book I mentioned in the previous post recommended always using the aperture on the primary lens, but other marcophotographers adamantly insist that IQ is better if you stop down the reversed lens. This suggests to me that neither system is intrinsically superior, but some lens combinations may work better with the prime lens stopped down, others with the reversed lens stopped down, so it is prudent to experiment with your combination.
For my part, using the SMCA 200 f4 plus reversed 100mm f4 bellows-Takumar, I always use the aperture ring on the 200mm (bellows lens wide open) because I use the rig primarily for small active subjects, and I want the lens to stop down then reopen to full aperture as fast as possible. Also, I usually use f16 for maximum DOF and a strobe for movement-stopping exposure time (both the subject's movement and my own). DOF is painfully shallow at 2X natural size, and any gain in DOF is worth more than a small loss of definition caused by diffraction.
ADVICE: When photographing at greater than 1:1, it is sometimes easier to move the subject than the camera. Set up camera + strobe on tripod or other rigid support; pre-determine a manually set exposure by experiment; cable release in right hand; hold subject in left hand and move it to frame and focus. Easiest to do inside where you can sit in a chair, camera on tripod or clamped to the edge of a table, left hand resting on table or beanbag on table top to move the subject. This method can be used in the field with the camera + strobe on a tripod and a monopod to help steady your left hand holding the specimen. Set up in deep shady spot so you can use strobe (if the sun is bright enough to allow a very short TV, chances are the images will have far too much contrast/dynamic range). Insects may be on a twig or leaf or flower that can be twisted and turned however necessary to get the requisite framing and focus. Trigger quickly with the right hand when the subject is anywhere near correct and take MANY shots. Shifting the subject forward-back a millimeter will completely change what is in focus. Moving the subject up-down, right-left four or five millimeters will ruin your framing. TAKE MANY SHOTS to get both the framing and focus you want.
AND DO NOT BE DISCOURAGED. Those of us who post deep macros regularly are commonly showing the best of 15 to 20 shots of that particular subject.
