For some strange reason people find Macro photography daunting . Probably because most of us end up eliminating all the wrong ways of doing it and end up giving up before getting to the right ways of doing Macro . So lets get to the most important part of Macro , light ! That's right , the most important part of Macro photography is light . You need light to lower your ISO , you need light to run a smaller aperture and you need light to maintain a decent shutter speed . If that sounds overly simple , well it is . Light is the secret to Macro . There , I have let the cat out of the bag !
There are more ways of getting light on the subject than I can cover , your imagination is the limiting factor . Now before I start giving advice .
These pictures were taken with the cheapest lighting solution I could think of , you are looking at pictures taken with a $10 USD solution . I call it my drinky cup flash . I used a 2nd hand drink cup from hungry jacks ( I drank the cola and cleaned the cup first ) . Then I used sticky tape to attach it to the budget ( low voltage trigger ) flash unit making sure to direct light to where needed . ( Focus point where the subject will be ) . Now do I need to mention how important it is to direct light at the subject rather that over , behind or in front of the subject . This may take some trial and error . ( Part of learning ) I will post a picture shortly !
So what have we learned ? A) You need light B) you need to direct the light at the subject .
So why are we doing this ? To lower ISO , use a smaller aperture and to maintain shutter speed .
Using a flash obviously increases complexity a little , but Macro is so easy that adding the flash simply makes the hobby more rewarding ( hopefully better more consistent results ) . Possible problems one may encounter usually revolve around reflected light and image burn . ( Too much flash ) It is easy to simply filter the light ( diffuse ) , make it softer / weaker ) . Simply by covering the front of the flash with printer paper or even a tissue can soften the flash .
Drinky cup flash with a tissue diffuse'r
So , if you are burning the image ( flash is too strong ) , then applying a filter to cut down the light is a very simple solution . On the other hand shooting at flat shinny surfaces can reflect light back to the lens and there is little to be done about this than to try and avoid shooting large flat surfaces at 90deg . Try and get a angle that reflects light away from the lens if possible , I know its not always possible , but keep the surface the subject is on in mind , or suffer the consequences .
Next I will talk about camera settings :
