Originally posted by EarlVonTapia Left out:
Question on the built-in flash: Can it trigger a Pentax flash (AF 540 FGZ) that is in manual mode?
If you mean can it act as a master to a slave AF 540, Earl, yes. And you can wind that power right back so it's only a catchlight to your external's key light. Forget 2 stops of flash exposure compensation, you can wind it back seven!!
And if you have a cable, Contrast Control Sync works as well.
These days the go is cheap radio triggers anyway ... more reliable than even the mighty Nikon in-built wireless system, which needs line of sight anyway. I have the Cactus v5 courtesy of the info in this forum.
Originally posted by EarlVonTapia Overall it seems oddly crippled in some ways. I'm not sure I would want this camera anymore, but hopefully it attracts the intended target into the fold.
And yet oddly more powerful than a beginner would need - more detail and sharper than the K-50 or K-5 II, for instance.
I think it'd make a pretty good second body to whatever you have now. [Edit: I see you've got a Q for that - there you go! It's not just Japanese Hello Kitty fans buying these things.]
