It does look like a step back but it's pretty close to the k-35/50/500 scores, but with some added resolution that isn't reflected here of course.
Originally posted by JPT One thing to note is that DXO awarded the same score to the K-5 II and the K-5 IIs, which means that the presence or absence of an AA filter is not reflected in their scores. So I would suggest that it doesn't tell the whole story. After all, the K-5 IIs does in reality output better files than the K-5 II by all accounts.
Their 'Overall Score' definitely doesn't take everything into account, they give a few more details here:
Overall Score - DxOMark
Unfortunately they don't give exactly how it's calculated (afaik), but they do give a little more on how the three 'Use Case' are determined:
Use Case Scores - DxOMark and imo these are more useful pieces of info than their overall score (but again, they don't tell you everything, just some usefull pieces though).
Given how they score things, you don't really expect much of a difference out of any of Pentax's 16mp sensor cameras, a list of the recent Pentax offerings:
Pentax K-S1 vs K-3 vs K-5 IIs: Different resolutions, similar Sensor Scores - DxOMark shows the k-5 series winning by 1EV dynamic range over the k-50/500/30 (Iso 80 vs 100 on the k5 series and 14 bit vs 12 bit maybe an extra kick?), but the iso performance is similar, a little better on the most recent k5ii versions. Did they get better at squeaking the most out of the sensor since the k5 or is it sample variation? I really would like to see them test 5-10 cameras of the exact same model to see how the scores differ across body samples. I wouldn't expect bodies to vary from copy to copy as much as lenses can, but it might be interested to see if this is the case.
