My K-S1 has gone from a panda to a unicorn tonight - I got the DA 40 lens. Is it ever tiny, and makes the combination even lighter, and silver definitely works with the white camera better than a black lens. And I had an interesting day photography-wise.
First, I wanted to take some pictures using a long shutter speed. I made sure that I took my tripod into work with me this morning, getting there at 5:40 am. Started off, saw something I wanted to take a picture of and realized that a tripod with a quick release head on it is only of limited usefulness if the camera doesn't have a plate on it. Ooops! So I did the best I could, and while I took some good pictures, any with more than a second shutter speed had camera blur. Sigh.
When I got home there was a box waiting for me - it had both the DA40 lens and a Cactus V5 Duo set. I've always gotten frustrated with flash, I just don't manage to get what I want. I found that I could get nice results with the K3 most of the time, but I really would like to figure out how to use flash more effectively. Since I often want a flash off-camera outside when taking pictures of flowers, I decided that buying the flash triggers made sense. I remembered about the tripod plate, so before I unpacked the flash triggers I searched madly for the generic plate, but couldn't find it anywhere. I finally gave up and decided to try my new toys anyway.
I hate doing comparison shots - something always goes wrong. I took a series comparing the K100 and the K-S1. Only problem was that I hadn't paid any attention to the fact that the K100 had that tripod plate I was madly looking for on it. So I had to re-shoot the photos. By this time I had unpacked the flash triggers, read the directions and tried them out. Do you know that the flash triggers don't work if the flash is still turned off??? I figured that out eventually (duh!).
Here's the final result:
I can't bounce the flash off my ceiling because it's tongue and groove wood, not white. I've tried before and I get really weird color.
First thing I noticed (which I hadn't before) is that there's no X mode like there is on the K3 and K5. I got the iPad out and looked it up in the owners manual. Answer for what I was doing - use M mode, set the shutter speed to 1/180 and then whatever aperture you want to use. Then I had to remember to change the flash to A instead of P-TTL. But I finally got things more or less the way I wanted them, and put the camera on the tripod (but only after removing the plate from the K100 and dropping the screw on the floor - took me 10 minutes to find it!).
I liked this one the best - it's probably a bit harsher than it should be, but it was after my normal bedtime.
One problem I have is that the plate I own is Acratech's generic plate that fits the K3. It's a bit too wide for the K-S1, it blocks the door on the bottom so you have to remove the plate to take out the memory card. I think either they or RRS makes a smaller plate, I'll need to check into that.
So I now have all sorts of new things to play with this weekend, and figuring out flash is going to keep me occupied for many, many weekends to come.
I am so delighted that I got this camera, it's really gotten me back into photography and is expanding my horizons more than I had expected when I first looked at it.
