02-09-2015, 07:45 PM   #1
bwDraco's Avatar
K-S2: 100 weather seals桸eeded because of the vari-angle LCD?
The email I received from Ricoh Imaging about the K-S2 specifies that the camera has 100 weather seals throughout.
100 seals!
That's 8 more than the K-3. I suppose some of these were added for the hinge on the vari-angle display. Is this why it took so long for Pentax to come out with a camera with this feature?
—DragonLord
02-09-2015, 08:06 PM   #2
I guess so! It's smaller in every way yet has more seals. The seal diagram shows seals around the screen and the joints and stuff.
It's also interesting that's rated to 32F instead of the usual 14F for Pentax's WR cameras, though the difference is probably just an academic matter. I'm sure people (especially here!) have gone way beyond temp specs without any real problems.
02-26-2015, 06:30 PM   #3
Docrwm's Avatar
QuoteOriginally posted by goodnight Quote
It probably has to do with the LCD screen being detached from the body and allowing air circulation around both main sides thereby decreasing its resistance to low temps. The LCDs mounted directly to the body benefit from a camera body interior temperature that is higher and takes longer to change to match the ambient temperature thereby insulating one side of the LCD better than the swing out version.
My favorite Pentax promotional images are the WR seals images
The more images like this one that Pentax puts out there the better IMHO. This one really sells the WR for the kit and the LCD is wet too (although its a bit cropped for my tastes).
02-27-2015, 05:14 AM   #4
gazonk's Avatar
waaaay beyond: https://www.pentaxforums.com/forums/6-pentax-dslr-discussion/31970-pentax-k10d-space.html
k-s1, k-s2, seals, vari-angle, weather
Vari-angle lcd for pentax dslr is less likely then mourinho managing England. Reportage Pentax DSLR Discussion 10 04-19-2013 05:53 AM
I keep wondering why Pentax does not add a Vari-Angle LCD? Reportage Photographic Industry and Professionals 7 08-12-2012 03:01 PM
Chances next body will be the k-5 + vari-angle lcd? Reportage Pentax DSLR Discussion 1 02-05-2011 04:48 PM
Can't see images on LCD because of reflection jendon Pentax Compact Cameras 4 03-24-2008 12:11 AM
Image of K20D weather seals falconeye Pentax DSLR Discussion 9 03-09-2008 09:55 AM
All times are GMT -7. The time now is 12:53 AM. | See also: NikonForums.com, part of our network of photo forums!
