02-17-2015, 10:38 AM   #1
Clothears's Avatar
K-S1 no card in camera
That's twice now I've taken a pic now with no card in the camera. The info screen does show an icon (bottom left) of a card with a line through it, but there seems to be no equivalent information in the viewfinder, which is where I mostly look for it. SWMBO says that her K100D won't take a pic with no card in the camera, and the K-S1 manual does list an error message to that effect but I'm not sure where it would appear.
I checked all the settings but couldn't see any setting to the effect of "ignore missing card" or similar. Anyone able to enlighten me about this?
02-17-2015, 11:38 AM   #2
THoog's Avatar
QuoteOriginally posted by Clothears Quote
I hate to argue with SWMBO, but my K100D certainly will take picture with no card. It just can't save it. I'm pretty sure the behavior has been the same for every Pentax I've owned.
03-02-2015, 06:38 PM   #3
Pepe Le Pew's Avatar
So put a card in?
Problem solved
03-08-2015, 08:58 PM   #4
I don't know about the KS-1 but the K-3, K-5 and IIRC the K-20 and K-10 all have the phrase "no card in camera" across the top of the rear display after you take a shot. It shows the shot but there is a clear message across the top of the shot.
NaCl(of course if you don't look at the rear display you are sool)H2O
03-09-2015, 02:50 AM   #5
Banned
As far as I know, the pictures can be viewed without the SD card in the camera. But for saving and transferring images, it is always advisable to use a SD card. You can check the following link for better information about SD cards compatibility with Pentax camera. K-x Recommended Memory Cards | Ricoh Imaging Support
03-09-2015, 03:57 PM   #6
Clothears's Avatar
QuoteOriginally posted by NaClH2O Quote
Yes, I see now that that is when/where that message shows. But I hardly use the screen so I don't see it. Just have to be more careful in future; I've purchased a USB cable so I expect to use that for image transfer in future (the card we were using in the K100D was an old SanDisk which had the useful attribute that one could snap it in two and then plug it into a normal USB port on the computer).
03-14-2015, 06:24 AM   #7
Kozlok's Avatar
A strategy that I have adopted is to never close the card door without a card in it. That way, when I pick it up, I can tell right away.
03-14-2015, 08:11 AM   #8
Clothears's Avatar
QuoteOriginally posted by Kozlok Quote
Dangerous with the K-S1. As the door is at the bottom and springs back to more than 90deg, you risk breaking it accidentally if you then plonk the camera down. I always immediately shut the door after removing the card (well, except that these days I'm using the USB cable so removing it less).
03-14-2015, 10:33 AM   #9
I've forgotten a card a couple of times. I now always carry a spare card in the camera bag for just those occasions. I've been looking at the rear LCD more and more now that it has such useful information on it when I first turn it on, so I'm more likely to see that there's no card. And I'm another who no longer leaves the card door open since I got the K-S1, it does look like some place that would be vulnerable. I find it interesting how my shooting habits have varied with just about every camera I've owned, they all seem to have introduced things that change how I've gone about doing things.
03-14-2015, 03:54 PM   #10
JimC1101's Avatar
As far as the K-X and K-30, it will always take a pic with no card in camera and then you will see the message saying that. When you go to a store and the demo is out, it will show that you can take a pic and the same will happen, it will shoot and no card in the camera.
03-14-2015, 04:20 PM   #11
Sandy Hancock's Avatar
I'm with Kozlok. My K-S1 goes on the desk next to the computer, upside down with the card/battery door open, until the card goes back in.
The same applies when I'm charging the battery.
03-14-2015, 07:23 PM   #12
robtcorl's Avatar
A plus for the K-01, leave the rubber flap door open as a reminder.
camera, card, card in camera, effect, k-s1, k-s1 no card, k-s2, pic
NO SD card in camera Bill Keesling Visitors' Center 26 05-06-2015 07:26 PM
No Card In Camera K-5 Hoopyjon Pentax K-5 5 09-28-2014 03:08 AM
645Z no card in camera problem elsdad Pentax Medium Format 2 09-06-2014 02:45 PM
No card in the camera - glad to see it! jamarley Pentax K-5 2 04-26-2014 05:29 AM
Pentax K-x False message "No card in camera" wedwardes Troubleshooting and Beginner Help 16 01-29-2013 09:50 AM
All times are GMT -7. The time now is 05:31 AM. | See also: NikonForums.com, part of our network of photo forums!
