03-10-2015, 03:08 AM   #1
fb_penpho's Avatar
What Windows, Linux Apps for WiFi
I have looked at the manual for setting up WiFi on the S2. So presumably when I press the WiFi button the camera will try to establish a link to the computer I have selected. But what is not stated is the application or applications that are capable of accepting a link from the camera. Anybody know what applications can accept the link and what can it do when it is established. thanks.
03-10-2015, 04:52 AM   #2
The camera will broadcast an ID, your computer must detect it and then connect.
Once that's done I assume it will show as a shared device.
I'm sure it's all in the manual
03-10-2015, 05:24 AM   #3
fb_penpho's Avatar
Steve, my K20 manual is 300pages and the S2 a more complicated camera 150. I have looked through the 150 pages and I cannot find any reference. Pentax as you can see have definitely cut back on the manual and vital information like the type I am asking.
03-10-2015, 05:38 AM   #4
Yes, the manual does seem to lack info.
It shows -P89 and in the specs P127 that the camera is probably running a dhcp client to connect to an ordinary wireless router which will give it an IP#.
But no mention of what protocol or software needed to access the camera. Maybe the camera is running http server for access by a browser?
Is there a supplementary instruction for this?
03-10-2015, 10:13 AM   #5
Otis Memorial Pentaxian
clackers's Avatar
I thought the phone app for this was released just in the last few days.
03-10-2015, 10:42 AM   #6
QuoteOriginally posted by wombat2go Quote
Yes, it does appear that the camera operates as a DHCP client. As for the tethering protocol, a Web service solution with camera as server is most likely, though a proprietary protocol would not be against the rules. (The tethering app is not browser-based and both IOS and Android provide ample mechanism for opening/managing sockets.)
03-10-2015, 10:51 AM   #7
https://play.google.com/store/apps/details?id=com.ricohimaging.imagesync
03-10-2015, 11:31 AM   #8
Is that for the wifi or the nfc or both?
03-10-2015, 04:31 PM   #9
clackers's Avatar
Wifi. Nfc is only used to cut out the step of joining the network and entering the WPA key.
03-10-2015, 04:52 PM   #10
Thanks
I could really use a proper tethering to my cameras here when I play around with optics etc during the winter.
I will be unlikely to purchase a new aps-c camera to do it.
The other constraint is that when using the cameras on, for example a bellows, the prism gets in the way , so my K-01 works best.
As a side note about downloading those Android apps, we have 4 Androids here. I tried to download an app and nearly went nuts because it did not download and shop kept saying it was downloaded.
A few days later, I found the problem: The download was going to another device that was switched on.
03-10-2015, 05:38 PM   #11
clackers's Avatar
Thanks
Well, for real USB tethering, there's nothing.
One day a variant of the 645's software might trickle down with an accompanying firmware upgrade.
Generally speaking, the K-3 is a tog's camera, the K-S series are for non-Pentaxians (although I have one as a superb second body).
03-11-2015, 09:33 AM   #12
fb_penpho's Avatar
Talked to my supplier who explained it as the following. The Camera acts as a 'master' an equivalent to a router. The app runs on the android device and accepts the link from the camera. There are no Windows or Linux programs (at the moment) that will work with the camera. So don't lose that USB cable any time soon, you will need it to transfer the files.
03-11-2015, 10:48 PM   #13
QuoteOriginally posted by fb_penpho Quote
I agree with that; reading the manual (page 92) seems to indicate that. The setup screen of the imagesync app connects to a device with a SSID, similar to connecting laptop or mobile to a router.
03-12-2015, 12:42 AM   #14
clackers's Avatar
QuoteOriginally posted by sterretje Quote
It's how the Flucard works, if you've ever used that, except you then follow the connection up with a web browser instead of a dedicated app.
applications, camera, k-s1, k-s2, link, wifi
Most useful iPhone apps for using with Pentax DSLR frogoutofwater Photographic Technique 12 02-25-2015 10:21 PM
GPS Apps For Geotagging? Leo315 Digital Processing, Software, and Printing 20 01-05-2014 03:56 PM
What's a good WIFI enabled compact? Shanti Canon, Nikon, Sony, and Other Camera Brands 6 12-18-2013 02:19 AM
Windows Phone photographer utility apps v5planet Pentax Camera and Field Accessories 2 06-15-2013 05:18 AM
Linux, windows, lightzone, & dual boot. regken Digital Processing, Software, and Printing 26 06-26-2007 05:14 AM
All times are GMT -7. The time now is 02:10 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
