Originally posted by mikesbike Very nice, and I'd say you've got the best closeout deal I have yet seen for that combo!! The DA 18-135mm lens is really quite remarkable too. In other brands, to get a body having WR construction, you'd be shopping in the $1,000 + range, and again the same for a lens having WR.
If you often shoot high-quality JPEG images, I recommend implementing "Fine Sharpening" in the Custom Image menus, especially in the most often-used "Bright" category. You can access via the "info" button. Just avoid having your mode dial set to the green Auto position, which will disable many controls and disallow adjustments. When wanting fully automatic exposure set by the camera, use the "P" (Program) setting on the mode dial instead. I noticed you are using Av in these photos, but I thought I'd provide that information for future reference.
Thanks for the hints. There are still things I am learning about the camera. Some of these were using manual lenses, so pretty much had to use Av mode to use the lenses, but I may have only shot a half dozen shots in green auto mode over the past year plus. With my old Canon Rebel XSI, green meant jpg only and default settings and I didn't like being trapped into the camera's settings.
I will check out fine sharpening. I use P a lot but trying to do more manual, so I've done some of the set aperture and shutter speed and let the camera select ISO - within limits. My instinct has always been to set the ISO as low as it will go, and generally I like macros so I set the aperture fairly wide open but getting to the point that that, too, has too many limits.. The 100MM macro that I got last year is great but I find the auto-focus distracting - it's 90% of the time in manual focus. I've been trying to break that habit back on the 18-135 because it's autofocus seems to work better. Anyhow... yeah. so many options. I finally played with auto-hdr mode last week. I am not a huge fan of HDR photography - it doesn't look real to me, but I am, on the other hand, trying to get the camera to do all the things it is capable of... if for no other reason that to understand. I have had debates with friends about the idea of post-processing vs. in camera, and one person insists that photoshop or Ansel Adam's darkroom work are great examples of the art of photography, and I get that. But at the same time, I would like to know my equipment well enough to take it and use the jpg as is and have the raw in case something needs tweaked - no more.
An example of my tests of Auto-HDR, a handheld and not particularly sharp but colorful image is here.
