Originally posted by Xtreme And why I need to tune AF on manual lenses ? Well, the hexagon and beep to verify focus are crucial at some cases when my eyes can't be sure enough.
The problem lays in the different paths. The path from the lens mount to the AF sensor might be slightly longer or shorter than the path from the lens mount to the image sensor.
I however would definitely not rely on the hexagon for critical focus. You will notice that once the hexagon is on, you can still change the focus distance slightly without loosing the hexagon; this means that there is a range in which the camera thinks that the subject is in focus.
The two solutions are to use focus-peaking or to get a 3rd party focusing screen (e.g. focusingscreen.com or katzeye). Not sure if focusing screens are available for the K-S1.
