Originally posted by ellicottva One quick question for you guys. I have a 64 GB SDXC card for my new KS-2. I have taken a few pictures that I want to transfer to my Macbook. However, when I insert the SD card into my laptop, it doesn't even recognize it's existence. So I am totally lost as to how I should transfer images so I could give post processing a try. Please help.
Check that the Finder - Preferences shows "CD and DVD ...", when this setting is it will also show a SD card on the desktop, if it's off then it will not turn up on the desktop but you should be able to see it when you open a Finder window, it should be visible under "Devices" in the left column.
You can transfer images to for example the Apple Photos, iPhoto or Aperture application. Just open the SD card and then open the DCIM-folder and inside you'll find folders for the different days and then images inside... just select them and drag them to the application of your choice and they will be imported.
A word of notice: If you plan to shoot RAW images with the K-S2, then please set the camera to the DNG format, not PEF (it is PEF by default factory settings). Currently Mac software like Apple Photos, iPhoto and Aperture can't interpret PEF files from the K-S2, (it's likely to come in a future update) but DNG works just fine. And JPEG's of course.
