06-10-2015, 12:03 AM   #1
Using fast 50mm lens for water polo photography
Hi Guys
I plan to buy a K-S2 and would like to try using a small (50mm) lens like the Pentax DA 50 F1.8 to take photos at indoor Water polo games from poolside (about 10-15m).
The lighting in most pools is terrible so i figure a big aperture's the way to go. What do you think ?
Cheers
Chig
06-10-2015, 02:06 AM   #2
redcat's Avatar
QuoteOriginally posted by Chig Quote
Pentax DA 50 F1.8
this lens is a good choice, cheap, fast, sharp and good in low light, you won't go wrong with it ^^
06-10-2015, 02:10 AM   #3
dms
If you want to get a larger "slice of the action" the depth of field with a 50mm lens at or near wide open will be too shallow (and the FL may be too long). And you will likely not have a long enough focal length to isolate the action. I suggest a zoom lens and a smaller aperture than you are thinking. I doubt if it will be that dark. I don't do this particular event but I would guess a 35 to 135 mm range would be a reasonable starting point. Also I would not try to totally stop the motion, especially as the feeling of water waves/spray may look odd if totally frozen.
06-10-2015, 05:08 AM   #4
fb_penpho's Avatar
I have seen a f2.8 70-200mm being suggested for this type of shot. Beware the lens tend to be heavy. Also you will probably need good ISO performance for the speed and aperture.
50mm, 50mm lens, k-s1, k-s2, lens, lens for water, polo, water, water polo
Best lens for wildlife using Pentax K-5 IIs on a photography tour Suhail Pentax SLR Lens Discussion 25 03-12-2014 07:22 AM
Fast lens for low-light photography Chaim Pentax SLR Lens Discussion 24 01-15-2013 05:19 PM
Fast, fast focusing 30-35mm prime? For dance photography Pheo Pentax SLR Lens Discussion 22 11-02-2012 07:57 AM
Fast Lens telephoto for low light concert photography? superfuzzy Pentax SLR Lens Discussion 49 12-02-2009 12:24 AM
K100D-Tamron 28-300 and Water Polo jsundin Post Your Photos! 2 02-27-2007 11:20 PM
All times are GMT -7. The time now is 02:01 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
