06-25-2015, 12:02 AM   #1
Just bought a K-S1
NOt sure if this is the right place to ask for help. Just bought a K-S1 and it takes fantastic photos.
Very pleased.
Unfortunately I can't use the supplied Digital Camera Utility 5 software that was supplied with the camera.
The software is installed Ok.
The camera connects to the computer and registers as a removable disk.
But the camera is not recognized by the Camera Utility software.
Any ideas would be greatly appreciated
06-25-2015, 12:27 AM   #2
max_pyne's Avatar
a general advice is to use a card reader.
06-25-2015, 01:14 AM   #3
sterretje's Avatar
QuoteOriginally posted by Hokumatz Quote
Can you explain what you mean by that?
If the camera shows up as a drive, that drive should show in PDCU as well. Personally I copy the files first to the computer's hard disk. Next I use PDCU for post processing the copied files (if necessary).
07-14-2015, 12:53 PM   #4
abe
He means that the software has problems and that a card reader is so much better and faster.
I suggest you go that way too.
07-14-2015, 02:19 PM   #5
Clothears's Avatar
Very pleased.
What operating system are you using? I am not using the supplied software with my K-S1 on my Macintosh. I use a suitable USB cable to connect the camera to the Mac and then just copy the image files onto the computer's disk. I use LightRoom to process the images. Are you making RAW images or JPEGs? Suggest you forget the supplied software unless you have a particular reason to use it.
07-14-2015, 09:52 PM   #6
jimr-pdx's Avatar
I'll catch up with you in a day or two & report back; I expect my K-s1 by Friday
While DCU has never been highly respected here on the Forums, it's silly to dismiss the facts:
  • it's Free
  • extremely Pentax compatible
  • extremely PC/Mac compatible
  • replicates Pentax camera features unlike all the others.
I've tried many others over time but I plan to make use of DCU5 when it arrives (I tried loading from the update but it must be installed before the download will function). That said I do have a card reader in my printer so I have more than one way into the system - but I shall try both soon.
07-15-2015, 05:25 AM   #7
abe
QuoteOriginally posted by jimr-pdx Quote
  • it's Free
Looking forward to what you find out about DCU.
I'm using lightroom and importing directly from the card at the moment and only tried DCU once.
Since I always do post processing I thought going lightroom right away was better.
07-15-2015, 05:34 PM   #8
I usually recommend Faststone, which is a free and very user-friendly pp program for quick and dirty adjustments. And the surprising thing is that when I finish my usual workflow then decide I want B&W, I just use Faststone's default grayscale option, and people comment about how good the monochrome pp is! No Nik or Topaz needed, just click one option!
camera, k-s1, k-s2, software, utility
Just bought a K-3 whats wrong with it imdunn513 Troubleshooting and Beginner Help 18 05-04-2015 12:26 PM
Anyone actually bought a K-S1 yet? capndan3 Pentax K-S1 & K-S2 8 12-11-2014 05:39 AM
So I just bought a K-30 lewvanbommel Pentax K-30 & K-50 12 12-29-2013 08:08 AM
I Just moved to a floating home & bought a K-50 Dids2 Welcomes and Introductions 3 12-10-2013 04:10 PM
New Here - Just Bought a K-50 and X-5 jwsamuel Welcomes and Introductions 8 11-29-2013 11:06 PM
All times are GMT -7. The time now is 09:07 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
