07-28-2015, 02:38 PM - 1 Like   #1
Fixed a wifi issue, want to share how i did it.
I was using the wifi application to take pictures while the k-s2 camera was on a tripod. The idea was to use the phone as a remote trigger.
I had a problem, the Image Sync app could not reach the camera. I discovered that although the phone was connected to the camera, it had a little "!' on the wifi symbol. In the latest android lollipop OS (android 5.02) I think that means the phone can not reach Google Services. This is obvious, since the camera is acting as a router which is not connected to the internet.
I think this is what happens, when the phone knows the connection is limited, it redirects all traffic away from the k-s2 network and instead tries to route it to the cellular data network.
So using that logic I disabled the data celular network on the phone and kept the camera wifi connected. The app worked fine, as expected, no problems whatsoever.
If any of you are having this problem maybe you can try this fix.
07-28-2015, 04:24 PM   #2
Caver's Avatar
QuoteOriginally posted by abe Quote
Thanks for sharing your findings! I have a Toshiba FlashAir II card (sometimes in my K-01, sometimes in the K-5II - just for fast transfer of the lowres jpg-s to the web) and I saw the exclamation mark near the wifi symbol on my phone. Next time when I'm using it, I will try your solution.
07-28-2015, 04:55 PM   #3
swanlefitte's Avatar
I can hardly connect via android. This might help.
08-10-2015, 02:15 PM   #4
this is unrelated to the S-K2's wifi but is caused by the device that has the 'Image Sync' application installed, e.g. a smart phone or tablet, and a deficiency in Image Sync. When the device has connection to the mobile telephone network and data communication has been enabled in the Mobile Networks settings menu, the mobile network will be the default gateway for IP communications, even when data communication via wifi or bluetooth is also possible. The phone or tablet hasn't been told where to send its data and assumes the default: mobile network.
The telephone's operating system would allow an application like Image Sync to not use the mobile network gateway but rather exclusively be routed to the wifi interface of the phone. A simple routing setting on the underlying Linux level would accomplish that. But it appears that the makers of Image Sync have not (yet) thought of adding that aspect to the app.
So, until that has been fixed, there is only the option to disable 'data via the mobile network' on the device that has Image Sync on it. The device's OperatingSystem will then assume the wifi interface to be the default gateway as mostly that gets preference over bluetooth connections that may also exist.
So it is not necessary to disable the cellular network altogether, i.e. for phone calls, but the data service over it needs disabling until a future version of ImageSync will have taken care of it only choosing the wifi interface.
08-10-2015, 02:24 PM   #5
QuoteOriginally posted by wwortel Quote
I have a Galaxy S4 and I didn't need to disable the data service for Image Sync to work. In fact, I didn't need to change any settings at all.
Sounds like Image Sync has some compatibility issues on different devices, though. They need to iron them out.
08-11-2015, 06:22 AM   #6
abe
I also think the problem is in the app that under some software environments fails to reach the wifi network.
wwortels clarification is important, you only have to disable data, not the phone network.
This happens to me in a lollipop android phone, more precisely a One Plus One.
10-05-2015, 08:04 AM - 1 Like   #7
YOU ARE A GENIUS!!!!
Hahahahah I even called customer support on Ricoh and they weren“t able to help. But your solution worked on my iPhone.
THANK YOU!
android, app, camera, connectivity, data, fix, k-s1, k-s2, network, phone, wifi
I think I get it, but want to make sure - SEL focus points jmerchant Pentax K-5 9 07-09-2015 07:32 PM
I Had To Share This. It's Just Precious....LOL magkelly General Talk 9 06-17-2015 02:51 AM
Figuring out Da 15 focusing - How I did it bpv_UW Pentax SLR Lens Discussion 12 06-01-2015 07:34 PM
I want manual HSS flash, how do I get it? asp1880 Flashes, Lighting, and Studio 6 09-07-2011 03:21 AM
what did I do wrong, and how to fix it? momof4 Photographic Technique 15 11-27-2007 10:15 AM
All times are GMT -7. The time now is 11:40 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
