08-04-2015, 09:07 PM   #1
K-S2 Firmware 1.10 available
Just a heads-up that there's a new firmware update available today.
Latest K-S2 Firmware Update : Software Downloads | RICOH IMAGING
08-11-2015, 06:36 AM   #2
abe
I updated like 5 days ago, no problems whatsoever. thanks for the heads up!
09-02-2015, 03:54 AM   #3
Picturesque's Avatar
QuoteOriginally posted by JPT Quote
There are two little errors in the Ricoh update page. KS-2 do not have USB 3.0 Micro-B slot, so you do not need USB 3.0 A to Micro-B cable if connecting KS-2 straight to your PC. It uses USB 2.0 and the slot is Micro-B. USB 3.0 to Micro-B is wider and do not fit to smaller USB 2.0 Micro-B slot. Second error is, that the update filename uses same name as the previous update. So if you already have the previous update on your SD card, you have to overwrite the previous version although the filename is the same.
firmware, k-s1, k-s2
K3 Firmware update 1.10 kev.pride Troubleshooting and Beginner Help 8 05-30-2015 11:00 PM
FirmWare version 1.10 buzzfotoz Troubleshooting and Beginner Help 6 07-14-2014 08:29 PM
K3 Firmware 1.10 Available DDoram Pentax K-3 1 07-09-2014 08:50 PM
K-x 1.01 firmware now available opiedog Pentax DSLR Discussion 115 01-23-2010 02:00 AM
K-7 - Firmware 1.01 is Available jbcampbell Pentax DSLR Discussion 34 08-04-2009 09:33 PM
All times are GMT -7. The time now is 12:52 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
