The Pentax K-S2 should work with the Pentax-M 85mm. Here is a photo on flickr with this camera/lens combination.
https://www.flickr.com/photos/igor_di_k/17254115971/in/photolist-shFRy8-rkVW...-wncfw6-wEbjiX
Regardless of the details about how to get the best from an M lens, if you have the camera set to manual focus, it should take a photo whether it is in focus or not etc.
Severalsnakes, are you sure the whirring is the shake reduction? My K5 is silent when I half press the shutter (if using manual focus).
---------- Post added 11th Sep 2015 at 02:07 AM ----------
CORRECTION:
Sorry - Sevveralsnakes was right, and I was wrong (about the compatability).
This is the key point:
First, if your camera won't fire, set "Allow aperture setting other than A" to 2 (allowed) in the custom function menu.
I guess I changed this in the menu on my camera so long ago that I forgot I had, and forgot you had to. That should solve the problem.
Still not sure about the whirring though.
---------- Post added 11th Sep 2015 at 02:35 AM ----------
Britta, have you tried turning the shake reduction off? If that is the noise, then presumably if you turn it off, it shouldn't make a noise. If it does still whir, presumably it is something else.
Anyone else have a K-S2?
