10-09-2015, 04:01 PM   #1
k5 iiS vs k S2
If you could get either at the current price of the K S2 (~$450), which would you choose?
10-09-2015, 04:45 PM   #2
mee
The K-5 IIs
Top LCD panel, 14 bit raw, faster burst mode, quicker min shutter speed, better (on paper) battery life, more solid body, optional battery grip...
10-09-2015, 04:53 PM   #3
Wingincamera's Avatar
It depends on what is important to you. For me I have the K-5 II, but the thing that sold me on the K-S2 was the fold out LCD screen and being able to use a cell phone for remote control if needed. I am not into sports photography so burst speed and the other items were not on my list. The battery on the K-S2 does not last as long as the K-5 series, but I have only had to switch to my second battery once. At the price difference if sports was important then the K-3 might be the way to go.
I have not used my K-5 II since getting the K-S2 and thinking about selling it. My wife thought she might like to use it, but since seeing my K-S2 she might just get her own.
10-09-2015, 04:56 PM   #4
They are two very different beasts. I do take advantage of the K-S2's wi-fi, tilting screen, and live view AF quite a bit, so I'd go for it if that's what you need. In other areas the K-5 still holds its ground and it has better ergonomics and battery life.
10-10-2015, 09:33 AM - 1 Like   #5
mcgregni's Avatar
There is no wireless triggering of accessory flashes from the K-S2 built-in flash, if that's a consideration. I find it strange, because Pentax have added the 2 stage manual flash power option to the KS2, (taken from the K3), arguably a ' sophisticated user' type of function .... So if you have one ' sophisticated' flash feature why not the other?
10-13-2015, 10:19 AM   #6
I'm still figuring out how much more beneficial 14 bits is over 12 bits. More is always better, but how much more. Does anyone miss having the 2 bits.?
10-13-2015, 11:39 AM   #7
QuoteOriginally posted by cla337 Quote
I was concerned about this also and after doing some research came to the conclusion that I would not be able to tell the difference. From what I read, the main difference is if the exposure is not right with 14 bit you might be able to recover more detail from the dark area of a photo. My main thing is landscape so it is easy to bracket the exposure if needed. So far using the K-S2 I have noticed any exposure problems.
10-21-2015, 03:50 PM   #8
jimr-pdx's Avatar
Personally I would take the more compact K-s2 with its newer feature set. The "trouble" is the K-3 price is also drifting into that equation!
11-11-2015, 05:37 PM   #9
beating an injured but not yet dead horse...anybody attest to IQ and Dynamic Range between K5ii/s and KS2? My issue is that my K30 is having the aperature motor failure (not opened during shutter) and it's too expensive to fix. So, looking at upgrades without having to spend too much. I have a set of primes that I'd like to use.
11-15-2015, 12:08 PM   #10
LoneWolf's Avatar
Horses for courses.
The KS-2 is the natural upgrade for the K30 with its similar user interface (menu system etc.). With the S-2, amongst other features, you get the anti- aliasing option to switch on or off as the subject matter demands. A weakness, if you can call it such, is that the grip is slightly smaller than the K30. Some can live with that, some cannot. Best to hold with your usual most used lens along with anything heavier you may have.
The K5ii/iis is a different and much heavier beast. They are much more professional camera and built like tanks. They have fewer features but are excellent in low light photography. You have to make the choice as whether or not you need an anti-aliasing filter based on your normal subject matter and your photo editing knowledge and skills in reducing moire. The K5iis seems to be more popular among forum members but that does not necessarily mean that it is best for you.Have a read at this before you make your final choice.
K-5 IIs -- The Pros and Cons of Omitting an AA-Filter - PentaxForums.com ---->
k-s1, k-s2, k5 iis vs
K-x vs K5 IIs or K3 MyTZuS Pentax DSLR Discussion 21 03-14-2015 09:04 AM
K5 iis vs K50/K30 SMeK Pentax DSLR Discussion 42 11-07-2014 12:39 PM
K-3 vs K5 iis sharpness peterjcb Pentax DSLR Discussion 16 08-09-2014 02:39 AM
Pentax k3 vs. k5 iis str8talk83 Pentax DSLR Discussion 11 05-11-2014 04:34 PM
k-5 vs. k5 IIs wltsang Pentax K-5 14 12-22-2012 12:39 PM
All times are GMT -7. The time now is 09:13 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
