11-29-2015, 05:28 AM   #1
Optical preview vibration
Hi everyone,
I'm still quite new to photography and I've been noticing that when I use optical preview at large apertures (1.8-6), the mirror (I think) appears to 'bounce' and the view through the viewfinder is jogged. While this isn't really an issue to me as it's very quick, should this happen/is it damaging the camera?
It's a k-s2 with da 50mm f1.8 if that is important.
11-29-2015, 05:52 AM   #2
sterretje's Avatar
Optical preview does not move the mirror. It simply closes the aperture. And at f/1.8 it actually does nothing ;-)
So not sure where your problem comes from.
11-29-2015, 06:23 AM   #3
Lowell Goudge's Avatar
With pentax cameras the image stabilization is the sensor, not the lens, therefore the optical preview is not stabilized.
11-29-2015, 09:29 AM   #4
11-29-2015, 11:42 AM - 1 Like   #5
QuoteOriginally posted by jabbershort Quote
It sounds lens issue. When camera tries to move the aperture lever on the lens, the optic part moves with it, thus the shaking in VF.
Mount another lens on the camera, and mount this lens on another camera if you have and see if it is unique to this lens.
If it is a new purchase, you should return it.
11-29-2015, 12:32 PM   #6
I've tried it on a couple more lens (18-55&50-200) and I'm getting the same effect, but it is much less noticeable (quicker and the 'bounce' is lesser). One of the lens is borrowed, but the others are both new. I'll take the lot back to the shop and see what they say. Thanks!
11-29-2015, 01:53 PM - 1 Like   #7
osib's Avatar
On k-50 mirror is for some reason linked with aperture lever, probably on k-s2 is same situation. On k-3 they are separate.
Hope this helps
12-01-2015, 03:06 PM   #8
QuoteOriginally posted by osib Quote
Hope this helps
That was my thought as well. I would contact Ricoh/Pentax and describe your problem to them. If your camera is new (less that a month old), I would contact the seller to arrange a replacement. What you describe is not supposed to happen.
12-02-2015, 04:28 AM   #9
So I went to a couple of local shops, and both of them had display copies which I tried and they had the same effect. I talked to the guys in both shops and they both came to the conclusion that it was just a quirk of the construction of the model and it was nothing to worry about, however one shop gave me the details of the local Ricoh rep and told me to contact them for proper confirmation. I have sent him a message and will post the response here when it comes. Thanks everyone for your assistance.
12-02-2015, 05:23 AM - 1 Like   #10
Not a Number's Avatar
Nice to have a couple of local stores that have the K-S2 in stock. I wish the situation was the same in the US.
Perhaps post a question in the K-S1/K-S2 section of the forum to see what other K-S2 users are experiencing. Or report your first post and ask the moderators to move this thread to the K-S2 section.
12-03-2015, 03:16 AM   #11
I've just got a response from the Ricoh rep, if anyone is interested:
"Hi Matthew,
There is no problem with the K-S2, this is the normal operation. There is one part which controls both the aperture and the mirror which is why when checking the DOF there is a shudder in the view finder.
I hope this helps.
Kind regards"
12-03-2015, 05:27 AM   #12
fb_penpho's Avatar
Could not find a problem
This entry forced me to check a feature I had not tested, mainly because I never use optical preview. Anyway, gave it a try, no problems on my camera, cannot even understand the explanation from Ricoh. Why should there be a shudder???
12-03-2015, 10:34 AM   #13
osib's Avatar
This is what I have write few posts above. It is little annoying that mirror is going up and down everytime you use optical preview or stop down metering but that is situation on mid-range pentax body.
Regards
camera, pentax help, photography, preview, troubleshooting
Optical or digital preview Gerrys Troubleshooting and Beginner Help 11 09-08-2014 07:56 AM
K30 optical dof preview Joojoo2010 Pentax K-30 & K-50 15 04-10-2014 10:29 AM
How to make sense of the DOF preview/Optical preview on the on/off dial ? photoleet Pentax K-5 5 04-17-2012 04:22 AM
optical preview question jag Pentax DSLR Discussion 6 01-10-2008 08:17 PM
optical preview request button Pentax DSLR Discussion 10 11-26-2007 04:39 PM
All times are GMT -7. The time now is 11:43 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
