03-28-2016, 06:55 AM   #1
Couple of questions about k-s2
I'm shopping for a replacement body for my k30, and have a couple questions about the ks2.
First, how is the screen outdoors? It's typically sunny out here in NM, and my k30 has to be cranked up exceedingly bright, which make it otherwise disturbing. I'm hoping with the articulating screen the ks2 will at least be usable in sunlight. What are your experiences?
Second, the review mentioned that the ks2 may be unbalanced with heavier lenses. The heaviest lens I have is the Tamron 28-75mm 2.8. Has anyone shot with this lense and cares to comment?
03-28-2016, 11:11 AM   #2
QuoteOriginally posted by Vmax911 Quote
The screen has a different coating than the K-30's, and I've found it to be easier to see. Plus, the fact that it can be tilted helps a lot.
I wouldn't consider the 28-75mm a "heavier" lens, so you should be fine with it. The K-30's grip is a bit deeper, though.
03-29-2016, 12:31 PM   #3
Wingincamera's Avatar
I use the K-S2 with a Tammy 70-200 F2.8 and have no problems with it. I have a tripod mount on the lens and when using handheld I use that to balance & hold the combo.
03-29-2016, 04:11 PM   #4
clackers's Avatar
Correctly holding a camera (from underneath, elbow down not sideways) will mean you have no problem, Vmax.
I use a 150-500 'Bigmos' handheld with an even smaller camera - the K-S1.
03-29-2016, 05:04 PM   #5
Sandy Hancock's Avatar
I have had no problem with the DA*50-135 and DA*300 on my K-S2. As clackers points out, holding the gear correctly helps.
And Adam is right about the screen. It's definitely easier to use in daylight than my K-01 was, and my Q7 is.
03-29-2016, 07:47 PM   #6
Excellent, thanks for the comments. Guess now I just have to pick a color!
03-30-2016, 01:38 PM   #7
swanlefitte's Avatar
I tried to use the live view today with f3.5 1/1000 and it was hard to see the screen. I didn't have it turned up tho. It increases 7 levels higher. I guess at 1/3 ev per time?
04-03-2016, 09:44 AM   #8
The LCD is slightly better readable in sunshine than the screen on K50. As somebody mentioned, you can also tilt the screen for better reading.
I do have bunch of "heavier" lenses, but the light and retractable 18-50 kit lens is just great with this camera for the right size and weight combination. BTW, the 18-50 kit lens is very good and sharp when focused in Live View mode or if you "AF fine adjust" the focusing for normal viewfinder use. I had to go all the way up to +10 with my copy of this lens. I am using as well the "plastic fantastic" 35 and 50mm lenses and they are excellent match for the S2.
04-11-2016, 03:19 PM   #9
Re the screen, we're just back from Vietnam - much more sunshine/bright light there than here in the UK. Though I usually use the viewfinder I used the screen a few times and it was plenty bright enough on its middle setting. In the UK I have the screen on -1 from the middle setting.
My heaviest and largest lens is the Pentax 80-320. It's fine, I hold the lens in my fingers with the palm of my hand under the camera.
couple, couple of questions, k-s1, k-s2, k30, ks2, questions, screen
A couple of questions about ACDSee Pro 6 NKK Digital Processing, Software, and Printing 5 07-04-2013 01:37 AM
Couple of K-x Questions? magkelly Pentax DSLR Discussion 23 05-29-2011 11:36 AM
A couple questions about lenses, reflectors and other aspects of photography! Noob Troubleshooting and Beginner Help 10 04-21-2011 12:15 AM
couple of K-X questions isusdfr Pentax DSLR Discussion 5 10-29-2009 05:55 AM
Couple of questions about the K20D.... Derridale Pentax DSLR Discussion 9 04-05-2008 04:06 AM
All times are GMT -7. The time now is 01:25 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
