04-08-2016, 12:01 PM   #1
fb_penpho's Avatar
Which parameters are mode dependent
Thought I would set up USER2 on my K-S2 for Flash, this got me thinking what parameters I would set. This followed on to a more fundamental question, what parameters can be manipulated, varied and stored for every picture mode available. What parameters are universal and thus the same and set for all modes. Maybe I have not understood the manual instructions but I do not know the answer. Is there one? All comments appreciated.
04-08-2016, 01:32 PM   #2
I believe that almost everything in the record menu, control panel, and drive mode/custom image/flash/white balance menus is fair game for being saved in a USER preset. Custom functions and camera setup parameters (such as LCD hue or flicker reduction) are always global AFAIK.
Now, if you're not using a USER mode, then there's only one set of settings that applies to all non-USER modes.
The camera also has a memory menu that allows you to configure which parameters should be reset after the camera is powered off. This is useful in ensuring that something like exposure compensation doesn't inadvertently stay on.
04-08-2016, 02:37 PM   #3
On my K-3II the manual states that settings that can be saved are Exposure Mode (except for Green mode), Sensitivity, EV Compensation, AE Metering, AF Point, Flash Mode, Drive Mode, White Balance, Custom Image, the Camera (camera symbol) 1-4 menu settings (with exceptions), and the C 1-4 menu settings.
04-28-2016, 10:46 AM   #4
fb_penpho's Avatar
Bug found with USER and manual lens
The problem is with Edial mapping when using FULLY manual lens (NO A PIN) and the USER settings.
When using manual lens with A pin, both Edial mappings work. When going to USER, both the Edial settings show up.
Replace the manual lens with a fully manual lens (NO A pin), then the Aperture Edial mapping ends. Not surprising as the aperture is selected by the aperture ring. However when going to USER, the shutter speed Edial mapping which had been available has also ended. This is the bug in V1.10. firmware.
k-s1, k-s2, mode, parameters, parameters are mode
which card is best for burst mode mictadlo Pentax Camera and Field Accessories 12 11-17-2014 05:31 PM
Pentax Close-Ups List, Verify Which Are/Are Not Achromats woody123 Pentax Camera and Field Accessories 2 06-12-2013 06:37 AM
Which settings apply to RAW mode, which don't? tempelorg Troubleshooting and Beginner Help 9 04-28-2011 09:47 AM
Which mode are you? Single shooting or continuous shooting? RonakG Photographic Technique 39 03-06-2011 02:08 PM
Which exposure mode for which lens? dosdan Photographic Technique 8 01-13-2009 11:09 AM
All times are GMT -7. The time now is 10:36 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
