Originally posted by Adam Is the lens cap on?
Also, what does M mode let you do?
Ha ha, No the lens cap is not on. I did check that and also checked to see if the lens was locked (it's the collapsible one)
I got desperate and switched to my Tamron lens that I used on my K-x and still no luck.
---------- Post added 07-21-16 at 07:59 PM ----------
Originally posted by scrapnmom2cnd Ha ha, No the lens cap is not on. I did check that and also checked to see if the lens was locked (it's the collapsible one)
Ok so I think I just found the problem.
This camera has two dials, the K-x only has one. The second dial is on the front of the camera with no markings so I totally missed it.
It just occurred to me that the dial highlighted was a semi circle shape like an arch. The other dial indicator had a semi circle shape like a U.
I swear I read the manual.
