08-07-2016, 01:35 AM   #1
How does "Custom Color Temperature" on K-S2 work?
In general the lower K value is, the warmer the environment is. The same goes for the higher K value. (is it?)
However in the camera it works conversely: the photo gets warmer with lower K value.
How does it come about?
08-07-2016, 02:25 AM   #2
I no longer have a K-S2 to test with, but on the K-1 higher temp values are definitely warmer. A bug, perhaps?
08-07-2016, 04:03 AM   #3
aremmes's Avatar
Lower K values correspond to a shift towards reds, while higher K values shift colors towards blue. This is because black bodies emit more short-wavelength light (i.e., more blue) at higher temperatures. The color data captured by the sensor is referenced to the color temperature to determine the balance across the spectrum.
08-07-2016, 05:34 AM   #4
@Adam: That's exactly what I'm wondering. I thought a higher K value should match more cool color before putting out this topic because it works so on the monitor.
aremmes (under your reply) gives his answer.
QuoteOriginally posted by aremmes Quote
@aremmes: So this function acts like color tone correction to adjust color deviation or to create a special effect? Seems I get something new
08-07-2016, 08:31 PM - 1 Like   #5
aremmes's Avatar
QuoteOriginally posted by FanFanD Quote
It does indeed help to correct for color deviation caused by differences in light sources. An ideal light source would emit light spread evenly over the visible light spectrum, but outside of the Sun most lights deviate from that in sometimes drastic ways, with the most obvious effect being that whites don't look quite as white as intended. The color temperature setting exists to help cope with that.
k-s1, k-s2, value
How to "extend" eyecup on K-3? AntonioD Pentax Camera and Field Accessories 14 07-28-2015 08:29 PM
Exposure accuracy of "A" lenses on older film bodies ("K" series) Lititz Pentax SLR Lens Discussion 20 05-26-2015 01:59 AM
"Reversal Film" custom image preset in K-3 Nimble Pentax K-3 7 05-05-2015 04:54 PM
"Click" in between "C" and "MF" mode on focus selector? K-50 maxwolfie Pentax K-30 & K-50 3 01-29-2015 04:19 AM
K-30 "AWB in Tungsten Light" setting does not work TropicalMonkey Pentax K-30 & K-50 6 11-30-2012 01:36 AM
All times are GMT -7. The time now is 08:42 PM. | See also: NikonForums.com, part of our network of photo forums!
