09-13-2016, 10:15 AM   #1
STEEWPHOTOGRAPHY's Avatar
Problem with K-S1
Hey Guys,
well since 3 days I have a problem with Pentax K-S1. It seems like all pictures are blurry and I don't know why!
Here is some of my footage from today.
I got also three little points on my images and my lenses and sensor are clean ....
I hope someone can help my :c
09-13-2016, 10:23 AM   #2
BigMackCam's Avatar
That doesn't look blurry - it looks like you're shooting with high ISO settings (hence the graininess in both photos, and in the top one, random colour noise too). What ISO were you shooting at in both photos?
Regarding the sensor "dots", the sensor can look clean to the naked eye, but still have dust particles on it. Do you own a bulb-blower? (don't do anything with it yet if you do, just let us know either way!)
09-13-2016, 10:28 AM   #3
I think I shot with 1600 on ISO.No I don't have a bulb-blower.
09-13-2016, 10:32 AM   #4
On my phone i can't tell. Check if shake reduction is on. To see if sensor is clean take a picture of a white wall or sheet of paper at f22. All dust shows clearly.
09-13-2016, 10:41 AM   #5
BigMackCam's Avatar
QuoteOriginally posted by STEEWPHOTOGRAPHY Quote
OK. I'd have guessed 3200 looking at that first one, because of the colour noise, but I can believe 1600. I'd have guessed 800 or so on the second, as I don't really see any colour noise.
Is there a good reason why you're shooting at such a high ISO setting? I assume it's because you used a very high shutter speed and/or a very small aperture (you definitely used a small aperture - f/16, f/22 or thereabouts, because you wouldn't see the sensor dust this way with a wide aperture). My question then would be, why did you need those settings? These are daylight photos with not much movement (save for the speedboat in the second photo), so you wouldn't need particularly high shutter speeds. Plus, considering the subject matter, I see nothing that would require an aperture smaller than f/8; in fact, you could go for a much bigger aperture (smaller f-number - eg. f/4 or f/5.6) on the bird photo...
Let's sort this high ISO issue out first, then talk about the sensor dust afterwards
09-13-2016, 10:47 AM   #6
Is there a good reason why you're shooting at such a high ISO setting? I assume it's because you used a very high shutter speed and/or a very small aperture 9 (you definitely used a small aperture - f/16, f/22 or thereabouts, because you wouldn't see the sensor dust this way with a wide aperture). My question then would be, why did you need those settings? These are daylight photos with not much movement (save for the speedboat in the second photo), so you wouldn't need particularly high shutter speeds. Plus, considering the subject matter, I see nothing that would require an aperture smaller than f/8; in fact, you could go for a much bigger aperture (smaller f-number - eg. f/4 or f/5.6) on the bird photo...
Typical newbie failure I did then I heard somewhere that you should take photos with a higher ISO because of editing it ? Well I will try out a lower ISO thank you for your help.
Well to the dust.I searched for a bulb-blower. Is a cheap one enough ? and what do I have to note ?
09-13-2016, 10:47 AM   #7
The spots are probably just dust on the lens showing up because of the insane aperture settings. This would also explain the softnesss you're seeing - when you close down the aperture the image gets progressively softer (diffraction).
Regarding ISO settings, it's best to keep it low - you probably got the advice of "better to use a higher ISO to have a sharp but noisy image" which is correct, but totally unnecessary in daylight
09-13-2016, 10:49 AM   #8
QuoteOriginally posted by Giklab Quote
well my lenses are clean. and I have it with both of my lenses.
09-13-2016, 10:56 AM   #9
Definitely the sensor then. I just mentioned it because you usually start seeing spots that are at the *back* of the lens at such apertures.
I use a cheap blower and it works fine, not sure about the differences vs more expensive models. I suggest facing the camera mount downwards when cleaning like this so any particles fall straight out and don't merely get blown around.
09-13-2016, 10:58 AM   #10
BigMackCam's Avatar
No worries, it's a learning process
It's usually best to shoot at the lowest ISO setting you can to support the shutter speed and aperture settings you want to use.
For the vast majority of day-to-day photography, you won't need an aperture smaller than f/16, and in most cases I would say no smaller than f/8. At these apertures you will be letting in much more light than a very small aperture such as f/22, so you won't need to use such a high ISO setting. Furthermore, as you set your aperture smaller and smaller (larger f-numbers), the detail in the image will actually soften due to something called diffraction.
An additional benefit of shooting at apertures of f/8 or wider (f/2.8, f/4, f/5.6 etc.) is that you won't see those dust spots on your sensor. These only become visible at very small aperture settings.
Can I recommend that you read, re-read and read yet again this article: Camera Exposure: Aperture, ISO & Shutter Speed
That will give you a good baseline understanding of exposure, and with that knowledge you'll have so much control over your photography, as well as an understanding of why certain things happen or look the way they do in your photographs.
I don't recommend really cheap blowers, simply because the materials and the manufacturing processes can be such that you have debris inside them. If you then use one to blow dust off your sensor, you can blow more onto it than was there in the first place. For now, I'd suggest you try shooting at apertures larger than f/16 (smaller f-numbers - f/2.8, f/4, f/5.6, f/8). You won't see the dust.
09-13-2016, 11:01 AM   #11
Thx I will definitely read the article
09-13-2016, 11:38 AM   #12
UncleVanya's Avatar
I will say that anyone who thinks dust will not show up at f/8 is not accurate. I rarely shoot over f/8 and I have shots a plenty that showed dust at that level. However at f/2 - probably not.
Also to clarify aperture is a bit of a curve. Wide open (lowest number on your lens) is softer than stopped down a little. So the lens gets sharper and has more Depth of Field (area front to back in focus) as you stop down - UNTIL diffraction starts to eat away at sharpness. Diffraction onset varies a bit and while I won't get technical here it can be assumed that around f/11 on any Pentax DSLR other than the K-1 that this starts to become an issue. The effects of Diffraction will vary in terms of tolerance and if you print vs. view on screen. So for maximum sharpness typically you want f/5.6-f/8 or so with most lens/camera combos in the Pentax world unless you are on Full Frame K-1 and then the numbers go up a little.
09-13-2016, 11:47 AM   #13
BigMackCam's Avatar
Interesting. I've never seen anything significant at f/8 - yet plenty at, for instance f/16. One thing is certain - the effect of sensor dust at f/8 is *way* less than at much smaller apertures, and I'd like to bet the OP won't notice these dust spots at f/8. It's possible, but not likely...
09-13-2016, 12:18 PM   #14
UncleVanya's Avatar
Several of my single in shots have been called out over the past couple of years for spots in the sky... none were over f/8.
But I may have had dust wagons rather than bunnies...LOL.
09-13-2016, 12:32 PM - 1 Like   #15
BigMackCam's Avatar
He he Yeah, I guess that's where they'll be noticed most... I took a bunch of shots whilst on holiday a few months back, and in fact there were a couple at f/8 where I could *just* make out a couple of smudge circles in the cloudless sky. It took me a couple of weeks to see them - they were barely perceptible... until I noticed them, and then that's *all* I could see
This is simply God's way of telling us we all need really fast lenses
bathtub, blow, bulk, children, guys, k-s1, k-s2, method, perfectly, toys
Fun with the K-S1 mtngal Pentax K-S1 & K-S2 275 3 Days Ago 08:14 AM
Hi new OZZY member with a K-S1 FLOSSEY Welcomes and Introductions 8 08-04-2016 12:29 AM
K-S1 problem Barso Pentax K-S1 & K-S2 13 04-24-2016 04:17 AM
Need help with old lenses for new K-S1 ccarlitos2 Troubleshooting and Beginner Help 2 12-29-2015 08:10 PM
Help with a K-S1 Copey Troubleshooting and Beginner Help 17 05-26-2015 02:56 PM
All times are GMT -7. The time now is 07:46 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
