Originally posted by Desperado
I had aperture block symptoms (one or two underexposed photos when the camera just started) with the sigma 17-50 f2.8 mounted.
Underexposed pics with the kitlens as well
Thank you very much for the quick response. I have also the K100D. Its solenoid would work properly in K-S2?
And after that repair will I be able to use my K100D with M (manual) lenses?
Did you meanwhile transplant the white Japan-solenoid from the flash-circuit of your K100D into the aperture-control of your K-S2 and the green China-solenoid
into your K100D (flash)?
It should give you 2 working Pentax bodies without any loss because the green China-Solenoid is less "stressed" in this very simply flash circuit of the K100D.
It works similar as in DVD drives, just a push on the flash-release button brings 7.2 Volts to the solenoid via a very simple transistor protected by a diode.
You just have to be careful, there is a tiny plastic rod connected to the mechanism in the K100D which pops out about 1,5cm behind the metal hook which holds the pop-up flash closed. This plastic rod can fall out when one removes the solenoid. If this rod is missing, the flash cannot pop-up anymore. Also a sign to watch out for when "not working" Pentax bodies are on sale such as this one
(The Germany text says as well: Ex-repairshop cameras, I cannot tell if parts have been removed or not.... but he sells repaired K30's etc. with white solenoid
