Originally posted by pjv Thanks for posting your testing method Nikolay. From the information you supplied, I think there is a problem. With those lens settings and camera to subject distance, the Depth Of Field is almost 32 meters. Here is a screenshot from a DOF calculator to check your information and also a link to the forum Fixing Focus tutorial. You may need to re-do your testing with a different method. Good luck.
Fixing Front and Back Focus - Introduction - In-Depth Articles I beg your pardon. The sample photo was 170mm not 200!
New rapid test is shown below : 200mm, AV f6,7, ISO100, 1/400s. The target was at 50-60m. Left is « -8 » AF Fine adjustment, right is zero adjustment. Each sample is one best from a series of 3 shots.
The result is obvious. I agree with your DOF estimation. My test shows that an incorrect adjustment (“0” instead of “-8”) moves the right focus by more than 13m (further, I think).
I think the best method to adjust AF should be taking 3 photos at each adjustment step (-10...+10 in the case of K-S1) and compare them. In such a way there is no mess with the adjustment direction.
Bu the way, I was surprised by the sharpness of 170mm shot compared to 200mm one at the same distance. To be continued...
