07-26-2017, 09:41 AM   #1
K-S2 Burst Issue
Hi Gang!
I have an issue with the burst on my K-S2. It will only burst for about 8-10 shots. Then I have to pause and start firing again after a few seconds. I suspected my SD card write speed might be too slow, so I bought a 16Gb Sandisk Extreme Pro 95mb/s. I believe the reported write speed is 80mb/s one of the fastest I could find. I removed most of the in camera processing settings, but nothing changed. It also behaves the same whether it is the high speed burst or the low speed burst. Is this just the normal function of this camera?
07-26-2017, 10:07 AM   #2
Senior Moderator
BigMackCam's Avatar
Assuming you're shooting RAW, this is normal... the buffer size is around 9 shots, after which the camera will take around 8 seconds to clear fully. You could shoot burst in high quality JPEG format instead, which gives you around 28 shots before the buffer fills.
All digital cameras have this kind of limitation to a greater or lesser extent. Basically, the camera is taking shots faster than it can process them, so they stack up in memory. Eventually, that memory (or "buffer") gets full. Those cameras with more internal memory and faster processing will typically allow more shots to be taken in a single burst.
07-26-2017, 10:45 AM   #3
QuoteOriginally posted by chunkiness Quote
Hi Gang!
And the faster SD card won't matter anyway as your KS-2 isn't capable of moving data at even half the speed that card can handle. So yes it's perfectly normal.
07-26-2017, 11:38 AM - 1 Like   #4
Thanks, I just wanted to make sure the buffering was normal. Using JPEG for bursts is a great tip, thanks!
burst, camera, issue, k-s1, k-s2
K-S2 PDAF issue Maerlyn Troubleshooting and Beginner Help 5 07-06-2016 09:20 AM
K-3 II burst speed faster in live view with K lens Leoi Pentax K-3 5 06-16-2016 08:15 PM
K-3ii + Sigma 70-200 HSM II Exposure Issue in Burst Shooting jawsy Troubleshooting and Beginner Help 3 05-27-2016 05:28 AM
Pentax S2 35mm SLR film winder issue Penduboy Pentax Film SLR Discussion 6 01-14-2016 11:57 PM
How to maximize K-50 burst rate? jswilson64 Pentax DSLR Discussion 12 11-30-2015 09:10 AM
All times are GMT -7. The time now is 06:41 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
