---------- Post added 05-14-18 at 10:23 PM ----------
[/COLOR]
Originally posted by ellicottva Hi Folks:
Just got the 70mm macro! I must say I'm confused because it simply doesn't want to set focus and keeps hunting in auto. Most of the pictures I've taken so far don't seem to be that sharp. Probably a learning curve involved in using this lens. I tried manual focus and unfortunately it isn't very easy to focus manually either probably to do with depth of field. Well, the lens looks in very good condition on the outside and the glass is very clean as well. Am I doing something wrong? Do I need to change settings in the camera before using manual focus? All I did was turn the button to manual on ihefront of the camera. Hopefully I'll get it down with some practice...
I'm a very big fan of checking a new or "new to you" lens for front or back focusing ASAP! This can help you not developing a bad opinion of your new lens. If its spot on take it out and shoot away. If it needs a little micro adjusting you'll see it right away and if its a bad copy you won't waist your time not getting the shots your expecting. It would be nice mount every lens and have them work perfectly but that's not the case nowadays 😟
Good luck!!
