Originally posted by Penview52
The most acceptable findings are these;
For DA F 4-5.8 the sharpness of object is 8.2 out of 10
For DA L F 4.5-6.3 the sharpness of object is 8.6 out of 10
They have both 25 degrees wide horizontal angle of view.
First look here:
Pentax DA L Zoom Lenses - Reviews and Specifications - SLR and Interchangeable Lenses - Pentax Lens Reviews & Lens Database Pentax DA L Zoom Lenses - Reviews and Specifications - SLR and Interchangeable Lenses - Pentax Lens Reviews & Lens Database
There is no DA-L version that has the f/stops of f/4.5-6.3. The DA-L version is f4-5.8 just like the SMC DA and the HD DA WR version. It is very complicated to talk about these lenses since three are nearly identical but not exactly the same.
I would also suggest that the user supplied sharpness ratings hold no objective factual relevance. These are purely subjective and there is not a test or any standard by which they are rated. Users often do not own multiple lenses of similar focal lengths and can't even subjectively rate them against one another unless by memory or reputation which is highly suspect. Looking above - if the DA-L you are pointing out is the f/4-5.8 which I think it is, the sharpness rating of 8.6 matches what I found in the database. Looking at the fact that the superior SMC DA only rated 8.2 which has the same coatings (SMC), the same exact aperture (f4-5.8), the same exact optical design, and the same focusing system (screw drive) and then has a metal mount, quickshift and a hood making it the better lens - and yet it is rated lower. In other words there is absolutely NOTHING in the design that should result in better performance. Any performance differences are either sample variation, a weird interaction with the plastic mount, or simply biased results based on expectation and price.
What's more reliable? Chart based tests can give some objective data, but that's only part of the way you evaluated a lens. Honestly finding shots online and viewing them to see if there are differences that you can spot is sufficient. In the few head to head shootout sessions I have seen between the HD DA WR and the HD DA WR PLM RE I have seen slightly higher telephoto sharpness on the older HD DA WR at the 300mm mark, but little differences below that and the differences have been very subtle.
I suggest these factors in this order should guide any decision between these lenses:
1) Does the newer PLM lens work on your intended camera(s)? Most modern bodies are covered back to the K-50 but notably exceptions exist (K-5 series, K-30). If it doesn't, upgrade your body or move on.
2) Does your budget permit you to consider the PLM lens over the older screw drive lens? If so, look further, if not pick one of the older versions based on budget. HD WR, SMC DA, SMC DAL is how these older lenses usually rank in cost from high to low.
3) Do you think the focus speed of the PLM or the slight advantage in aperture (1/3 stop at most) or slight sharpness advantage at 300mm for the HD DA WR is more important? If you think focus speed - buy the PLM. If you really need the extra aperture speed - consider trying to stretch for something like the DA* 60-250 and the HD DA 1.4x tc or a 300mm prime, or take the HD DA WR and don't look back.
