11-15-2018, 09:27 AM   #16
I have the same problem, the first few shots are dark, rapid shutter use or four or five releases seems to clear it.
I've looked at a number of comments, and many suggest that the solenode sticks due to residule magetism.
In old relay technology this was delt with by a small pip on the armature that prevented total contact, and assisted quick release by reducing the affect of the residule magnetism.
I've tried to find a diagram / image of the assembly to see if this is a practical solution, not that I think it's my job to do design mods for Pentax but because it's XXX annoying.
Any details would be appreciated as I would like to know what the problems are before risking pulling my camera apart, can anyone offer info.
11-15-2018, 09:37 AM   #17
retired sw engineer
reh321's Avatar
QuoteOriginally posted by David Marriott Quote
Welcome to Pentax Forums.
There are a whole lot of discussions about this issue in the K30 & K-50 Section.
https://www.pentaxforums.com/forums/151-pentax-k-30-k-50/
I really doubt we want to repeat them here. In summary, the issue is much more complicated than residual magnetism; the current solenoid seems to have both a new plastic {PET instead of teflon} as well as a new metal.
11-15-2018, 09:52 AM   #18
QuoteOriginally posted by reh321 Quote
Pentax K-30 & K-50 - PentaxForums.com
Thanks for that, is there a way of knowing the part number for the new version as there is no point fitting one of the old type?
11-15-2018, 10:32 AM - 1 Like   #19
retired sw engineer
reh321's Avatar
Read this page in particular.
K-30 / K-50 Aperture Block Failue - Repair Solution available - Page 51 - PentaxForums.com
The problem is with new solenoids, which seem to have pale green plastic; old solenoids, which seem to have pure white plastic, seem to be the ones you want.
A guy on eBay has made a business taking solenoids out of old cameras and selling them
Pentax K-30 K-50 K-S1/S2 K-500 Genuine Aperture Solenoid Plunger Part - Japan - | eBay
One of the problems here is that all parts have the same number, regardless of construction of the solenoid; the only difference is how they 'age', which normal acceptance inspection would never catch.
03-18-2019, 08:11 AM   #20
....... the only difference is how they 'age', which normal acceptance inspection would never catch.
Not the only difference but:
1. Holding force of the early DSLR white made in Japan solenoid is not as strong
2. Material: White solenoid is made out of teflon (PTFE): better bearing abilities
3. unknown: Material composition (alloy) of the plunger
03-18-2019, 12:01 PM   #21
retired sw engineer
reh321's Avatar
QuoteOriginally posted by photogem Quote
We don't disagree here.
The solenoids work OK when the camera is new.
When I talk about "aging", I am saying these factors cause the solenoid to change over time so they no longer meet requirements.
For example, the teflon "wears' better than the PET does; the metal's magnetic/mechanical qualities may change over time.
Catching changes that will occur in the future is not what Acceptance Inspection does.
06-13-2019, 04:21 AM   #22
I ended up buying a DA 18-55 lens as the 18-135 isn't available. I won't buy the k-s2. I'll let him use.my k-5ii on this trip. Sad because the feedback of the k-s2 is good except for this problem.
aperture, block, camera, cost, failure, k-s1, k-s1 aperture block, k-s2, lens, repair, report, shots, takumar
K-500 Aperture block failure? findus Pentax K-30 & K-50 28 06-09-2018 08:44 AM
K-500 aperture control block failure - how screwed am I? tobyshootspentax Pentax K-30 & K-50 12 01-09-2018 07:11 PM
K-S1 aperture block failure timw4mail Pentax K-S1 & K-S2 9 10-26-2017 10:21 AM
Do I have aperture block failure (and where do I fix it)? redridinghood Repairs and Warranty Service 5 03-29-2017 08:25 AM
Is it worth it to repair Aperture Block Failure? Patti_M Pentax K-30 & K-50 14 02-21-2017 01:31 AM
All times are GMT -7. The time now is 05:24 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
