04-03-2019, 09:44 AM   #1
K-S2 overheating and other issues
I just purchased this K-S2 body from Amazon Warehouse ($275). It had less than 500 shutter count and looks to be in mint condition. The listing stated minor cosmetic damage, but there was nothing I could find. I was pretty excited, thinking I got a steal...and then I tried it out.
Problem 1: It overheats. Or, at least, it claims it is shutting off due to overheating. This is after less than 5 minutes of use. I turn it back on, it goes for a bit, then repeats the same overheating message and shuts down. (the camera itself does not feel hot)
Problem 2: Pictures are great when using the display view. However, if I switch to the viewfinder (in Auto or Scene modes -- indoor pictures) all pictures are bright white. The shutter speed doesn't go above 1/15. Switch back to display view, and all is well. If I switch to T or Tav, pictures come out great through the view finder as the shutter speed adjusts as needed (1/128, 1/256, etc).
Yes, I can send it back for a full refund. However, due to the great price, I wanted to check and see if someone had an easy fix
Thanks!
04-03-2019, 10:04 AM - 1 Like   #2
Hmm, neither of those sound familiar to me. I've never had a shutdown due to overheating. Unless you're shooting in an oven, that alone would make me think about returning it.
As a longshot, maybe try reset to factory defaults and update the firmware?
04-03-2019, 10:08 AM   #3
Docrwm's Avatar
Send it back it's broken. Good luck.
04-03-2019, 11:43 AM   #4
Otis Memorial Pentaxian
QuoteOriginally posted by h2dk Quote
To echo the good doctor (above)...Send it back, it's broken!
P.S. Welcome to the Pentax Forums!
04-03-2019, 12:01 PM   #5
Thanks, that's what I figured
04-03-2019, 12:07 PM   #6
Docrwm's Avatar
Sorry. Pentax cameras are generally very reliable. I've been using them under all sorts of weather conditions for 10 years and never had a problem. I hope you choose to stay with Pentax for the replacement. Welcome aboard!
04-03-2019, 01:56 PM   #7
swanlefitte's Avatar
Sounds broken but hail Mary factory reset. Also check the battery compartment for corrosion. If none send it back. If yes try a quick cottonbud clean then probably send it back.
Liveview shouldn't be white in auto unless the sensor is shorting. That explained overheat also.
04-04-2019, 06:41 AM   #8
I also have a K-S2 and I confirm that I never had my device shutting down because of overheating, nor exposition problems. Clearly something is broken with that particular camera and you should send it back. Too bad since it's a great camera otherwise!
display, k-s1, k-s2, pictures, shutter, switch, view
K-3ii Overheating & Freezing Up Imagery By George Pentax K-3 & K-3 II 2 09-03-2018 07:14 AM
Recording time and overheating differences between models Canid Video Recording and Processing 45 08-27-2018 07:34 PM
KP Overheating? To KP or not... MrStupid Pentax KP 28 07-12-2018 09:50 PM
Has Pentax K1 overheating issue? corvaz Pentax K-1 & K-1 II 14 09-19-2017 02:12 PM
k-x overheating in video mode jupzchris Video Recording and Processing 3 05-24-2010 03:38 PM
All times are GMT -7. The time now is 06:26 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
