Originally posted by ShawnH
Thank you so much.
When the center point is adjusted (+9), the extreme left and right focus points are not sharp. However if I use the center point and recompose then areas correlated with those points are sharp enough. This is with 35mm f2.4. Other lenses have the same issue but not to this degree. I guess it is a combination of mirror and lens as you suggested. I thought there may be a way to individually calibrate focus points I will run some tests using Live View (eliminating the mirror) to see if right and left of the image are soft. The sensor on KS2 is razor sharp. At least focus and recompose works well enough.
True: the 20mp sensor on the K-S2 in my opinion is very sharp. In fact, I find it as sharp as the K-70's 24mp...if you think about it, the 4mp differential is small and the slightly larger pixels provide even more light capture.
If the 35mm f2.4 has the most aberration, what other prime lenses have you used that show slight softness. As you know, some lenses are designed (certain SONNAR designs, for example) to be "softer", though almost any digital exposure in center focus, is sharper than the average film SLR of yesteryear if calibrated equally, IMO.
