Originally posted by stevebrot Use care. The screws are JIS cross-head and not Phillips head. Under torque from a Phillips driver, they driver may rise in the slot and strip the screw.* JIS screwdrivers are strongly recommended when working on Japanese cameras or lenses having cross-head screws.
* Stripped heads are a common sign of clumsy repair attempts on lenses and cameras. If I see them on a listing photo, it is an automatic no-buy from my perspective.
Yes, Steve, I agree that you make a very good point here about JIS drivers. I was wary of stripping screws heads, but I managed with a #000 Phillips. Another thing I was careful of was that nearly all of the screws bed into plastic holes, and feeling proper torque before stripping the plastic threads is tricky.
---------- Post added 10-10-19 at 01:29 PM ----------
Originally posted by photogem Good luck! And yes, report back!
Thank you for your encouragement, photogem! I did this successfully, but I used the filing technique (which I know you do not recommend) rather than a white replacement solenoid -- I have no soldering equipment with tips small enough to work in that tight area. In brief, the camera is restored to full functioning.
To save time here, please see
this thread at DP Review, and my comments as "drummercam," where I have described this effort. I left a ground wire unattached (which I did not expect to find) for lack of the soldering equipment. I expect you can identify the purpose of the wire, because I can find no loss of function.
