10-07-2019, 05:56 AM   #1
KS-1 exif lens info
I wonder if anybody else had the same problem before. My KS-1 suddenly stopped saving lens info in the EXIF.
No matter which lens, the line that's supposed to have the lens name in it is always empty.
I wonder if that's a setting issue or a weird software/hardware bug.
10-07-2019, 06:15 AM - 2 Likes   #2
Something like this would normally only happen if the electrical connection with the lens is lost. In such a case, you'd also see F-- in the viewfinder and AF wouldn't work.
It could also be a software issue- how/where are you reading the exif? Have you tried uploading a photo through this tool to see if the tags are there? Lens exif is a little bit tricking because the camera doesn't actually store the lens name, but rather a code, so it's up to the software to figure out what that code means.
10-07-2019, 10:46 AM - 1 Like   #3
Otis Memorial Pentaxian
As Adam noted above, the camera writes a numeric code into the makernotes section of the EXIF and always writes something, even if the lens does not pass it an ID code through the mount data contact (e.g. "0 0" for no lens detected, "1 0" for K or M series, "2 0" for A series). Note that with very few exceptions, only auto-focus lenses pass a code to the camera. If you are not seeing a lens name, the most likely cause is that the software you are using does not support that feature or lacks a name in its look-up table for the code that is there.
Have you recently changed software for reading EXIF?
10-08-2019, 05:56 AM   #4
I normally use my ACDSee 9 for EXIF and development (not the best but at least quick). My guess would be on that software as the tool link (thanks Adam) shows the lens perfectly.
I guess it's time to upgrade the software then...
Thanks guys
exif, info, k-s1, k-s2, ks-1, ks-1 exif lens, lens, wonder
DigiKam losing exif info from K3 images Dr.T Digital Processing, Software, and Printing 7 10-24-2019 02:23 AM
Exif FL info is wrong for Tamron 28-75mm pentaxfall Pentax SLR Lens Discussion 13 04-04-2018 01:07 PM
KS-1 and KS-2 Back from Precision Repair..Finally GuitarGuru76 Pentax K-S1 & K-S2 6 02-18-2018 02:30 PM
EXIF: No Lens Info for DFA100mm/2.8WR? twokatmew Pentax SLR Lens Discussion 3 06-20-2010 01:16 PM
Showing "Lens" Info in EXIF Data twokatmew Digital Processing, Software, and Printing 4 02-24-2010 01:27 PM
All times are GMT -7. The time now is 07:28 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
