Originally posted by cfrpcopy
I followed this guide and all I got was:
- A shock from the flash capacitor
- A small brass washer (see attached) (not the ring in step 16)
So I'm calling the procedure a success! The instructions were excellent, aside from not mentioning this washer.
Well done!
- This washer you found was used in very early K-S2 versions, because there was small difference in height which needed to be corrected,
it belongs here onto the bottom plate and is fixed with the same red thread-locking laquer used to fix the solenoid:
- There is another black ring which sits on the microphone-socket:
This one is very important for WR!
- The flash capacitor is so well protected in the K-S2 and K-70 (both indentical for changing the solenoid) that I am surprised you got a shock.
Discharging it with either a lightbulb or a resistor is more complicated and more dangerous due to the fact that the radial leads are well protected, meaning also that touching them for discharge could very easely lead to shortening them, i.e. killing the capacitor.
But particular for eliminating the danger of a shock I gave clear instructions of how to discharge this flash-capacitor anyway.
It is in the tutorial for the K-S2 (and any other tutorial I wrote for all the other Pentax bodies with solenoid) as well as there
is a tutorial just for this:
How to discharge the photo-flash capacitor of a DSLR (here K-30/K-50/K-500) - PentaxForums.com
Did you follow those instructions? It is easy and every time I tested this method it worked well.
Obviously, I won't know if it's really fixed for a while. I only had early signs of failure: it happened when the camera first turned on, and I could clear it with a few clicks of the DOF preview, but I wanted to get this fix over with. But it works fine right now, and the donor was a *ist DS, which should have had an authentic old-style solenoid.
It is fixed if you did a good soldering job. If the problem returns, the only because one of the two wires would not have been soldered well and comes off again. I had this once.
The Japan-Solenoid which you easely can distinguish by the white color of the PTFE body against the green PET body of the China Solenoid was built the only one used in the *ist DS and it never failed.
