Originally posted by Kai-Luke
Having tested the modification of the U-shaped plungerer Sergio suggests it looks like this
But the very bad results are terrible.
I have taken some photos of a no dog poop sign to show it.
The K30 is still open because it got a white Japan solenoid afterwards.
F2,8 (Sigma F2,8-50mm AF-macro)
F11:
F18:
F25:
Afterwards when exchanged against the white Japan-Solenoid, all was fine.
To access the switch behind the diaphragm control unit you need to take the Pentax apart complety.
Having done so with a K100D just for fun, I never can recommend this on a K-30 or K-S2.
I also ask this question
Pentax K10D, K20D, Samsung GX10 and GX20 use the Japanese solenoid and are known to reach very high actuation numbers.
Why they never fail, nor K200D, K100D, ist and all other before K30 which use the solenoid?
It makes sense, it is logical.
Because the Japan solenoid works well.
Not necessary to take the Pentax apart.
Another question:
If I make this effort of complete disassembly of my Pentax I must take photos of each step.
Complicated soldering involved.
Many soldering points and wires which need to go back exactly to their place.
Everybody on modern days has a smartphone with a useful camera good enough to take such photos.
Dear Kai-Lucas: a pleasure to greet you.
From the photos you have uploaded it is clear that the solenoid you modified has lost the magnetic retention capacity, which has to be a minimum of 150 gr. according to what I explained in my post # 47.
If the solenoid does not lock, a fact that has to happen by a mechanical blow produced by the Aperture block when lowering the mirror when the photo is finished, it is because Plunguer's legs are very short, or there is some imperfection in the polishing of the surfaces that prevent the blockage.
I suggest a length of Plunguer's legs of 4 mm, but this length must be verified with a caliper, because the armor of the different sets of solenoids can be different dimensionally. You have to ensure that the legs reach the armor and a minimum light is produced between the heads of the coils and the Plunguer of at least 0.2 mm.
After you practiced the slots or reductions that I suggest in post #144, you must verify that the Plunguer is magnetically retained at least with more than 150 gr. You should study the graphics developed in post #91.
If the Plunguer does not lock, it will be permanently unlocked and loses the possibility of electromagnetic unlocking at the exact moment sent by the perforated crown of the Aperture block, which will select the diaphragm aperture determined by the processor. This is the reason of the overexposed photos you have taken. Directly the system stops working.
This modification of the solenoid, is designed to take advantage of a weakened signal of the Aperture block, and has the advantage of being able to be done without welding ability. Now if you have the white solenoid, use it and that's all, otherwise try to lower the consumption of green by following these tips.
My Ks2 camera, works with the original and reduced Plunguer without any problem. I have already sent many photos of it where it is shown to produce consistent exposures.
I hope this helps you.
Attentive greetings
---------- Post added 01-31-22 at 10:02 PM ----------
Originally posted by sergiogonzalez
Dear user community of Ks2.
Happy 2022 with a lot of health and many good photographs.
I want to tell you that my Ks 2 has already reached 15200 shots and I no longer experience the dreaded ABF.
I've been going over everything written in this thread, and the post that best describes the ABF problem is post #29. It accurately describes why the solenoid fails as a result of a poor electrical signal from the aperture control.
Doing the maintenance to this control is essential after about 4 years of use of the camera. This in turn allows us to maintain the design of our cameras.
The green solenoid has the electrical, mechanical and magnetic characteristics that the manufacturer has determined for the excellent and consistent operation of the aperture control.
Belittling the Chinese industry at this time I think is too much.
With this criterion we should think that every modern Pentax camera has lowered its quality by having most of its components of that origin.
It is irrefutable that the green solenoid works well in most cameras and also that it does well at least in its first 3 years of use.
This maintenance consists of renewing the lubricants and checking the state and quality of any electrical contact, static or dynamic of the system.
All the details are explained in some post of this thread.
A good guide to lubricants to use in cameras is in this same forum in the following thread uploaded in 2011 by Pacerr. He apart from suggesting lubricants gives applicative criteria in the different parts that can help those who venture to do the maintenance of their camera.
I hope it will be useful.
Lubricants - PentaxForums.com
Attentive greetings
Dear Swanlefitte:
A pleasure to greet you in this 2022
Thank you for following this thread and your confidence in everything published.
I understand that intervening the Aperture block is a very complex operation and requires maximum qualification in welding and understanding the disassembly and assembly using equipment and measurement procedures that not everyone has or understands.
I have tried to explain as well and as clearly as possible all the procedures, but it is so complex that even having videos of the whole operation it would be very difficult to explain it.
Readers should also understand that my Ks2 is the only camera I have, and when intervening, use freehand graphics and reference photographs to then reconstruct the wiring.
Thank God, I did not have any accidents during the intervention, which allowed me to continue enjoying my Ks2.
Best Regards!
---------- Post added 01-31-22 at 10:05 PM ----------
Originally posted by swanlefitte
I will not refute this. Your camera is evidence this is so. Yet if It has been shown I do not need that much electrical signal with a white solenoid, then why is this the preferred method? As white solenoids become rare this might be preferred.
Thank you for the update on your repair.
Dear Swanlefitte:
Best Regards!
Read more at:
Dark frames or dark expositure problems in KS2, K30, K50, etc. - Page 11 - PentaxForums.com
