Originally posted by stevebrot Are you saying you attempted a "hot" swap in the middle of an interval series? I have never tried it, but suspect that the interval series was "dumped" and restarted in a new folder using the same start point.
FWIW, use of an external power source is strongly recommended for extended interval work. Even the larger battery on the K-3/K-3II is not able to do more than about 700 exposures.
Thanks for the answer.
I pressed the info button after the shutter completed a shot to look at status, and it gave me the option to cancel, so I cancelled the interval "session". At first that was an accident, I thought it would remove the info screen, but it told me something like the "Interval Completed" or something, and then I could see the battery symbol was red, so I went ahead and put in a fresh battery and started over again. At the end of it I dumped the images to my laptop, and that's when I noticed the file naming was duplicated (yes, must have been a new folder).
I haven't tried to experiment with external power on the K-S2 but if I go out west again and do nighttime shots, or videos, or the like, I may want to do it. There's no factory option is there? (I am sure Google or the forum would tell me).
