Originally posted by unclerickety I have uploaded a picture and checked the info, don't know what I am looking for so screenshotted it for you to see, Is there anywhere in the UK that I can buy the white solenoid as the one on the link is in the states and postage is 33% on top of the purchase price, thanks
---------- Post added 04-21-21 at 12:43 PM ----------
Yes, thanks, I have had a look and hoped I wouldn't have to strip out the camera but would be happy to do so as a last resort, If I stripped it out I could see if the solenoid worked by putting a voltage across it,
A solenoid is an electric switch so should either work or not, has anyone done this and what power should I use without frying it. The power pack for the camera is 7.5 Volt.
I think what the others said is right. The solenoid is going. Basically, the aperture isn't opening up to what the camera thinks it is set to. Let's say you take an image at f4, well, since the solenoid doesn't allow the aperture to open then the camera thinks the aperture is f4, but the actual aperture is f22.
You can still use the camera with a lens with an aperture ring but otherwise you have to decide if it is worth fixing (or if you can do the job yourself).
