Originally posted by Ronald Oakes Ok...Soooooo....let's get on with it and change the sick solenoid with a good used white one !
No point in beating around the ABF issue and discussing it to death.
I wasn't aware that anybody discussed the ABF to death?
Originally posted by Ronald Oakes Your camera is still fully functional using Takumar lenses, or updating your firmware and using one of the newer PLM lenses.
Well, it isn't fully functional using Takumars because one can use Takumars as well in Av-Mode but that option is not working as it could but only with exposure compensation.
It is fully functional for using any lens with an aperture ring and setting aperture manually on the lens using the green button mode
or using Av-Mode plus exposure correction.
So not only Takumars but no DA or others without an aperture ring.
And yet: It is still a very castrated K-S2 and not what it was intended for.
Originally posted by Ronald Oakes I also have a 2017 made KS2 that suddenly developed ABF last month. I didn't think the later made ones had an issue.....well.....obviously....They Do !
Yes, but much less if built after Dec. 2015!
Most K-S2's are built before. About 90% of 'em.
We now have another situation which is very interesting because the repairers truly messed it up:
KS2 repair frustrations - PentaxForums.com
