que es tu: Good luck!
I recommend the
Vessel 9902 JIS screwdriver-set, it is far superior to the Moody set.
The Moody-set looks nice but when I first got it years ago it turned out to be just PH but named JIS.
Maybe they changed that.
The Vesselset is much shorter as well but you want the length of Vessel
@ehrwien
A proper JIS 00 or 0 will work for the solenoid-screws, that is the good thing about Vessel, they fit that well.
PH works but it is then a must to use PH000 for the solenoid screw, a PH00 would destroy it (which a JIS 0 won't, it fits as perfect as the JIS 00)
The 3rd hand clamp hint is misleading for soldering wires!
One unsolderes first the wires off the solenoid while it is still fixed in the Pentax, no matter which one!
Then one unscrews it.
Then one inserts the Japan solenoid and screws it in tightly.
Then only one solderes the wires back on (no need for a 3rd hand clamp, it is not possible)
I guess you used the 3.rd hand for unsoldering the wires of your donor solenoid?
@i-trax: IMO a misleading message about non-availability of the Japan-DSLR-solenoid and that somebody told you that because actually it was different/the opposite
(as it was me quite
HERE post #13 in this thread you started!)
You where given the same link on ebay.com which I always gave here in this forum of the seller potmano, located in California USA who sells the correct Japan DSL solenoid on ebay.com.
There are at the moment 2 solid/safe solenoid sources, one on ebay.com (seller potmano) and the other on ebay Kleinanzeigen Germany.
The other ones: One source on ebay UK (seller randr2012) and one on ebay.de (not to be mixed up with ebay Kleinanzeigen Germany) which are tricky offerings, i.e. SLR solenoids and not DSLR! The German sellers (kilo404) kind of admits this at least, the UK seller doesn't but stopped selling them.
But another offers it now on ebay UK with an iffy text.
