Does anyone have an L bracket they like for the K-S2, one that they like for Arca-Swiss-style tripods? I have an L-bracket that was
advertised on eBay as being for Pentax K-5, K-3, and K-70. It does not work; my K-S2 rotates forward when I take vertical shots with a heavy DA* 50–135mm lens.
This L-bracket looks like a generic MPU-105 in my opinion; it has six little rubber pads on the bottom but no rubber pads on the side. The K-S2 has slightly curved sides, and I think the lack of a right angle encourages unwanted rotation.
I don't care much about access to batteries or headphone jacks; I'd be happy to unscrew the L bracket when I need to recharge.
This L-bracket does work fine with my smaller, lighter lenses, just not with my DA* 50–135mm. Why oh why doesn't this lens have a tripod collar, again?
I've read old threads on this topic, but nobody seems to have a great solution:
Originally posted by WondringLisa Hi all,
A short time ago I purchased a quick release L bracket for my K-S2, however I am having a problem that I have had with other plates that is exacerbated by the size of the L bracket. No matter how tight I try to secure it, it will still shift easily and I can still get gradual downward creep on my camera when securing it in the portrait orientation. Does anyone have any suggestions/fixes/hacks that will prevent it from moving once tight?
Thank you!
Lisa
