Show Printable Version 1204 Likes Search this Thread
01-18-2016, 06:21 AM   #316
Tips
My tips are as follows:
* Always always always keep a UV 0 filter on your lens. It may cost 50 dollars, but that is much better than replacing a 700 lens due to scratches.
* Lens hoods are your friends.
* Never use SD cards with less than a speed of 4.
* Humming birds will test your willpower and diligence. (And your camera! 1/4000?!?)
* Don't buy inexpensive straps!
* And my favorite.... get out of auto mode!
George
01-18-2016, 06:59 AM   #317
QuoteOriginally posted by r0ckstarr Quote
Regularly check your exposure. Lighting conditions change from tree to tree, or branch to branch. A cloud passing over will still change the amount of light you have in shadows.
Tav mode is my solution to this problem. It's not the only solution, but it allows you to cope with changes in lighting without taking your eye off your subject and missing the "moment".
01-18-2016, 07:15 AM - 4 Likes   #318
D-I-Y Accessories
Need an accessory, think D-I-Y. This picture shows two flash units adorned with empty cake frosting containers for diffusion. The flash on the right is mounted on a cheap pawn shop microphone stand with 5/8-27 female to 1/4-20 male thread adapter available on ebay. I've also used multiple layers of frosted cellophane tape stuck to pop-up camera flashes. All kinds of stuff can be used for photography applications with a little imagination.
PENTAX K10D  Photo
Last edited by Apet-Sure; 01-18-2016 at 07:20 AM. Reason: Image didn't load first time.
01-18-2016, 07:27 AM   #319
Legacy lenses have potential !
The time has come for us to offer the final prize from our Holiday Giveaway! Enter in this thread for a shot at winning a brand new HD Pentax-DA 55-300mm lens
How to enter:
As a reply to this thread, post a photography-related tip or suggestion for fellow users. It can focus on cameras, lenses, technique, accessories, post-processing, or other related topics you think would be helpful.
Limit your submission to no more than 5 sentences and no more than 1 image/link.
Winner selection:
The top 15 replies with the most Likes in this thread will be voted upon by forum members in a separate thread, similar to how we pick our monthly contest winners. Submissions will be accepted through January 31st, and voting will be between February 1st and 8th.
Submissions may be compiled into a reference article to serve as a community resource.
Good luck!
Just a quick tip I've picked up along the way:
Many of us own lenses that were designed for 35mm film cameras. This is a great reason to shoot Pentax because lenses made back in the 1970's will still work on our newer DSLRs. A rule of thumb I use for these "legacy" lenses is the format ratio of about 1.5:1. In other words, an older lens of 100mm will produce an image equivalent to a 150mm on a DSLR. If designed for a DSLR, the lens focal length is as stated on the barrel. This can help one put together a nice selection of lenses without duplicating capability. Moon shot with legacy 35-200mm zoom handheld.
PENTAX K-5  Photo
01-18-2016, 07:33 AM - 3 Likes   #320
Shoot film!!!
Modern digital cameras are wonderful, but let's join together as Pentax users and keep film alive. I'm looking forward to showing my grandkids how to develop and print black and white film in a couple years when they can appreciate it. Then, I will point out to them that the most significant photos ever taken -- flag raising at Iwo Jima, Abe Lincoln, Beatles, etc., etc., -- were taken in this manner. Attached, a photo of my grandfather (center) with some friends taken in 1920. p.s. - want some fun? Take an old photo like this and try to recreate it with relatives of the people in the photo. I found this exact rock, 90 years later, in the park where this was taken.
01-18-2016, 07:35 AM - 3 Likes   #321
My two tips:
  1. Pretend you're shooting with film again. Yes it's easy to rapid fire away with digital because it's "free", and I admit I've captured moments doing this that I likely would not have gotten with film. But every now & then I'll pretend I have film in the camera and I find I'm talking a lot more time & care, end results are excellent and I find it's way easier on the "delete' key when going through a session.
  2. Dig out one or two of those old film cameras, load 'em up with some ASA 100 (or whatever your preference) and head out shooting. If you've got a couple of bodies load one up with B&W. Send the film away to a good lab. I've taken pictures with an old Spotmatic with the super takumar 50mm prime lens that I've yet to match with any of my current cameras. Waiting for & getting the envelope back with your images brings back a flood of memories, and the satisfaction of seeing good results several days (or weeks) after the fact is well worth reliving.
That is all.
ps. count how many times you look at the camera back after a shot while your shooting film.
01-18-2016, 07:39 AM - 1 Like   #322
Hello Everyone, I Do wedding and Family photography, Itīs so challenging!! but I love it. I use a K20D and manual off camera flash, you know that a K20D have a lot of problems focusing, speed and High ISO quality is bad, but that is not a limitation to make good pictures, even in fast situations, here are my advices.
1, Know your gear, from head to tail, use it with eyes blinded, thatīs key, you can't struggle with technical adjustments, when you are in a hurry.
2, Anticipate! eyes wide open, all the time, let your guts guide you!
3, Use battery grip, I can't imagine working without one, makes so confortable and balanced your camera, remember that I use a FA* 28-70 (so heavy after 6 hours)
4, Its all about light! Don't expect to have great results without great light, if there is not a good day light source, learn to use off camera flash and create your own quality light.
5, Good Lenses, good lenses good lenses!
01-18-2016, 07:41 AM - 1 Like   #323
UncleVanya's Avatar
QuoteOriginally posted by iquest35 Quote
This is wrong. The focal length doesn't act different depending on the format the lens was made for. The 1.5 crop factor applies to any lens used, not just film era lenses. So a 50-200 DA-L set at 50 gives the same basic angle of view as an M 50 or even an old screwmounr Takumar 50mm. All 50mm lenses give a similar field of view as a 75mm on a 35mm film body.
01-18-2016, 07:44 AM - 1 Like   #324
QuoteOriginally posted by skrewloose Quote
I usually end up with 3 copies. 1) computer's hard drive (until I need more space), 2) backup drive, 3) another backup drive (copy of #2 at a less frequent interval)
+1. I also organize my photos in chronologically named folders that are ~4G in size. I burn these onto DVDs and keep copies off site.
01-18-2016, 07:48 AM - 3 Likes   #325
helios
here's my tip:
anyone that owns a pentax should get a helios lens. (unless you hate creamy delicious pictures with awesome bokeh)
When I first started with my pentax I had barely shot anything in manual mode and didn't know much. Getting a manual lens and getting out of auto is a great learning experience and the payoff is beautiful
PENTAX K-S2  Photo
PENTAX K-30  Photo
01-18-2016, 08:10 AM   #326
Late afternoon, around sunset and a slow shutterspeed, gives beautiful
seascapes. Be sure to use a tripod.
01-18-2016, 08:28 AM - 1 Like   #327
Creating "small planet" images for free
Hi!
I'm sure many of us are familiar with the technique but here's how I make reasonably hi-res "small planet" photographs using free software only--possible with any camera, but my "flagship" hobbyist eqipment is a K-50 (surprisingly First, take about 25-30, partially overlapping horizontal shots to create a 360 degree panorama (aperture at f8--hold steady, keep the sun out of the frame--if you can--and try not to deviate from the horizontal too much). When finished, use the Image Composite Editor by Microsoft to stitch the individual photos into a horizontal panorama, then transform the panorama into a "small planet" image with the help of the (also free) GNU Image Manipulation Program (GIMP), choosing the "Filters"; "Distortion"; "Polar Coordinates" option from the drop-down menu. Experiment and enjoy!
01-18-2016, 08:29 AM - 1 Like   #328
f22
Using Post Production to transform a photo
Using post product tools to alter which elements of a photo are emphasized can dramatically change the feeling of a photograph. Attached is an example of a scenic tree, which has Spanish Moss dangling from the branches. The original photo started out with the leaves creating a predominantly green cast to the photo, and was not very dramatic. By increasing the highlight control about 15%, bending the tone control, reducing the shadows a small amount, and boosting exposure about 1.5 EV, it brought the Spanish Moss into the forefront of the photo, and really changed the whole feel of the original photograph.
PENTAX K-50  Photo
01-18-2016, 08:30 AM - 2 Likes   #329
Tip: When shooting in any wildlife rich area, always be aware of your surroundings. While you are highly focused, stalking that perfect osprey, eagle, or egret shot, something might be stalking YOU!
Eric
01-18-2016, 08:34 AM - 11 Likes   #330
enoeske's Avatar
You can create cool effects that add atmosphere by using a combination of action freezing flash and slow shutter speed blur.
Model: PENTAX K-3
ISO: 1000
Exposure: 1/6 sec
Aperture: 2.8
Focal Length: 17mm
Set the camera Tv mode and try using slow speeds around 1/6 while moving the camera. Side to side, or spinning in a circle like turning a steering wheel work great. Everything will be blurry, except where the flash hits and freezes the action.
55-300mm, body, camera, day, dust, effect, elements, exposure, focus, fungus, giveaway, hd, hd pentax da, iphone, k-5ii, lens, pentax, pentax da 55-300mm, pentax-da, pictures, post, regards, shots, submissions, thread, time, tip, win, word
*READ ME* Tips for being successful in the K-3 photo contest Adam Site Suggestions and Help 0 04-29-2014 03:25 PM
Joining the Pentax Community from Seattle, WA, USA Nial Welcomes and Introductions 4 01-01-2012 01:54 PM
READ ME: FINALIZED 5th birthday giveaway information found here. Adam Travel, Events, and Groups 5 10-01-2011 04:28 PM
Pentax DA 55-300mm lens--help me decide charliezap Pentax SLR Lens Discussion 29 10-07-2010 05:14 PM
All times are GMT -7. The time now is 05:21 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
