Originally posted by rkappleby
I was having the same problem with my Sigma 500 and sent the lens into Sigma, the fellow I have been dealing with told me that the Pentax contacts are somewhat smaller than competitors, and they did note that the screw heads on the lens mount were slightly deformed likely from stress over time, they are replacing the screws and applying thread lock. Hopefully this will tighten things up and allow proper contact. You might check to see if your screws are tight or if there is any notable deformation.
I will check those screws, thanks!
---------- Post added 02-25-2016 at 09:16 PM ----------
Originally posted by pete-tarmigan
Some or all of the contacts on the body mount and/or the lens mount could be oxidized or dirty, preventing electrical conductivity.
Another possibility is that the aperture ring on the lens has been knocked a little off the "A" position.
Thanks for the info, I have checked the connections, but I will again.
---------- Post added 02-25-2016 at 09:18 PM ----------
Originally posted by stevebrot
Short answer: There is no continuity on the "A" Contact.
Possible causes, ordered by likelihood:- Dirty/oxidized contact on lens or body
- Dirty mount face on lens or body
- Aperture ring not fully in "A" position
- Damaged (warped) mount flange (body or lens)
- Fault in lens (broken solder joint or failed circuit board)
- Fault in body (broken solder joint or failed circuit board)
The mount face and contacts may be cleaned with a microfiber cloth. To determine the last two points, I would suggest testing continuity of the "A" contact to the mount face on both with an ohmmeter. If you feel there is an electrical fault present, you can attempt a self-repair, but before cracking open either the lens or body, consider that
Ricoh will not sell you parts. You will need a known-good junk body to scavenge from.
Thanks for the input!
I will check those connections. I have seen just the flange on ebay before. I don't think that's the problem, I think it just came apart from the body.
I wish they would just sell parts. My K30 died right after the warranty period, still have it around, perhaps I could use it for a doner. Not sure if they are compatible.
---------- Post added 02-25-2016 at 09:21 PM ----------
Originally posted by DeadJohn
If it's happening with multiple lenses it's probably the camera. The screws on the camera mount may have loosened on one side. Since it's the second time they've loosened, the screws or holes might be partially stripped.
You could try to remove the screws, make sure the mount is positioned properly, apply a thick non-permanent thread locking compound to the screws, and carefully reinstall the screws without overtightening (and without dripping any thread locker into the camera). Be warned that you'll void the warranty, and even after you get the mount mechanically in place there could be further electronic issues.
The benefit of warranty service is they should fix it correctly, replacing parts instead of just filling the stripped holes. The risk of warranty service is that it can take a long time and they might say it's not covered by the warranty.
I'll hedge on recommending what you should do. I'd need to look at the mount to see whether the screws are stripped before committing. Good luck however you proceed.
Thanks DeadJohn, I will inspect if further. I understand this will void my warranty. Warranty is kind of useless for me. Like you said, I am not going to wait weeks and maybe just find out it isn't covered. Disappointing, but what can you do. I'll check it out and take some pics with my macro lens, see if I can sort it out.
---------- Post added 02-25-2016 at 09:23 PM ----------
Doundounba, Thanks for the info and links, I will check them out. Glad to hear you have a successful repair, gives me hope.
---------- Post added 02-25-2016 at 09:28 PM ----------
If you have the extended warranty card and camera proof of purchase, it should be covered. The sequence goes like this:
- You send the camera to Precision along with warranty documentation and a description of your problems
- Precision receives your camera and contacts Ricoh/Pentax for payment approval
- If payment under warranty is approved, your camera will be serviced or replaced. I am not sure at what point this determination is made.
- If payment is not approved, Precision is supposed to contact you to determine your wishes
- If payment is approved, Precision is supposed to update the job status on their Web site
- Precision is supposed to contact you when your repaired/new camera is being shipped
If things go awry it is often at step two with Ricoh/Pentax not being prompt in providing authorization and Precision not being diligent in requesting action. The other difficulty is when parts are not in stock and not readily available without delay. Precision has not been very good at keeping the customer (you) in the loop.
If you feel that the Web site is not helpful, you can contact them directly by telephone to find the best way to get your warranty service started.
Wow, thanks for detailed info. I contacted Precision and they told me to contact Pentax direct. Pentax of course told me to send the camera to Precision. So didn't get very far. I just wanted to know if it would be covered without sending it in and waiting..
What really ticks me off is that this camera was "my" camera. It was babied since day one, bought brand new of course. My wife's K3 was bought used. It already had some signs of wear. She isn't as careful with hers as I am with mine. So why am I stuck with the problems? Ha...
Thanks for everyone's input. I will inspect it and snap some shots.
THANKS AGAIN!
