03-10-2016, 05:20 PM   #16
BigMackCam's Avatar
QuoteOriginally posted by mee Quote
I'm guessing a crackled screen could allow water to get into the camera, depending on the design behind it. So may want to consider that too if you take it out during rainy or very humid times.
Agreed... but the screen protector should significantly reduce that possibility... plus, if the cost of repair is at least $300, and with the price of the K3 sinking lower and lower - particularly for used examples, with owners upgrading to the K1 - I would take the risk and, if the worst happens, simply replace with a new body.
03-10-2016, 06:28 PM   #17
That is not correct.
That is the BASE estimate. It will never go down from there... only up.
Things may have changed. What they told me in Spring of 2015 is that it may go either way and that the card is not charged until the estimate amount is approved by the customer. I suppose I could give them a call since neither of us has had a relatively simple repair (like LCD cover replacement) done there.
In case anyone is interested, here is a how the repair is done, assuming you are able to source the part:
https://www.lensrentals.com/blog/2012/02/how-to-change-your-cameras-lcd-cover
Note the cost of the replacement.
base, camera, cost, estimate, k-3 repair, lcd, lcd on k-3, pentax help, pentax service, photography, pm, post, repair, service, troubleshooting, warranty
The rear LCD screen on the K-3 kshapero Pentax K-3 20 10-16-2014 12:15 PM
Cleaning K-3 rear LCD screen Burr Baughman Visitors' Center 6 08-10-2014 05:03 AM
FA 31mm Ltd. on K-3: Focal length disappears on LCD Ztrejfer Pentax SLR Lens Discussion 3 04-15-2014 07:54 AM
K-5 Cracked Top LCD SPO Troubleshooting and Beginner Help 14 12-02-2013 03:30 PM
Repair referal 100d replace cracked lcd spb37 Pentax DSLR Discussion 6 05-26-2008 12:46 PM
All times are GMT -7. The time now is 04:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
