Some might have read that my K5IIs crashed to the floor with the Bigma attached.....it pulled the mount out of the camera. After much struggle to remove the mount from the lens I found the Bigma to be unharmed but the K5IIs a mess at the mount area.
With nothing to lose, I tried to put the mount back on....3 of the 5 screws still anchor, the mount itself appears to be very slightly bent, but I am able to mount a lens on it and it works.....
in MF only and with no aperture control.
There is a little ring type washer that came off directly behind the lens mount flange. I stuck it back in there but think it is all wrong...I never could figure out how it mounted or what purpose it served?
I intend to send it in for repairs when the K1 arrives, but maybe if I could get that ring right it would be OK? I know it's a long shot, but maybe worth a try?
Currently I am using it with the Bigma back on it, but no aperture control and no AF. Everything else seems to work fine and the body is not cracked or damaged in any visible way.
Any help will be appreciated greatly!
Regards!
Rupert
