05-01-2016, 09:36 PM   #16
No... A dedicated m42 screw mount camera wouldn't have to remove the k mount adapter.
That's the simplicity of having two bodies. With one body, you either have to constantly be changing out the adapter to use normal pk lenses (this is a pain) or purchase an adapter for each lens (this starts getting expensive). So my K30 with the kipon adapter is essentially an m42 camera that always depresses the aperture pin and allows stop down metering - something the official pentax adapter does not do. On other threads, the kipon adapter was judged to be well built but difficult to remove, but since I never remove it no problem. Good luck with whatever you decide to do, but I will say, the old lenses add a bit of fun and variety to shooting.
05-02-2016, 09:01 AM   #17
Ahah. Thanks for the info.
Will stop down metering still work if the aperture lever has stopped working ?
05-02-2016, 09:27 AM   #18
UncleVanya's Avatar
QuoteOriginally posted by Ian.morgan Quote
On m42 it will. On a k mount set to stop down and not keep aperture open it will.
aperture, ir, k-30, k-30 aperture lever, lever, option, pentax service, repair, service, warranty
Are all Tamron 18-250s this loose? Should I fix it or return it? cadmus Pentax SLR Lens Discussion 16 06-06-2015 09:19 PM
Getting K-3; Sell my K-30 or keep it? Sdenby Pentax DSLR Discussion 22 12-31-2014 02:34 AM
Is it worth it to get the k-5, or will the k-x do?? Moz Artistic Visionz Pentax DSLR Discussion 19 10-03-2011 06:34 PM
Is it ethical to purchase a camera, the use it and return it GregK8 Pentax DSLR Discussion 31 01-23-2011 05:31 PM
smc Pentax-M 50mm F1.4, fix it or let it be? Manel Brand Pentax SLR Lens Discussion 5 10-31-2010 06:33 AM
All times are GMT -7. The time now is 03:06 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
