That is awesome! Thanks for the info!
Cheers
---------- Post added 04-26-16 at 09:24 AM ----------
Originally posted by dcshooter The front of the MX is pretty easy to remove.
Pry off the little plastic dot on the self timer and remove the screw holding the timer handle on. You can then peel off the front leatherettes and get access to the 4 screws that hold the front plate on. The front then pulls up and off. Just be careful not to break the meter wires, which will remain attached. You should then have access to pretty much the entire shutter linkage and might be able to see what's wrong.
Here's a thread where I provided some pics showing how the front removes:
https://www.pentaxforums.com/forums/8-pentax-film-slr-discussion/311985-locat...ontacts-2.html
You can see the shutter linkage shaft below the MX logo in the 3rd pic.
When you reassemble, just be careful
One question though, what do you use to reattach the leatherettes? I am assuming the glue wont be good for reattachment.
Cheers
