07-13-2016, 11:59 PM   #16
MilkaSchokoHase87's Avatar
Thanks, but the problem is, that I can not focus at 0.45m. itīs blocked. The Limit is between 0.55 and 0.6m (as you can see on one of the pictures).
=( I didnīt know where the error is.
07-14-2016, 01:36 AM   #17
QuoteOriginally posted by MilkaSchokoHase87 Quote
loose the screw on the focus barrel and adjust it and re tighten it
07-14-2016, 03:31 AM   #18
thanks, but I hope to get solved my problem of close focus
---------- Post added 07-14-16 at 03:38 AM ----------
QuoteOriginally posted by niceshot Quote
would be fine if it will be as easy, but for this I had to do some dissambling first =(
07-14-2016, 08:24 AM   #19
Great Thanks, I will try it tonight and let you know tomorrow =).
07-16-2016, 12:45 PM   #20
Great Thanks for the trick DCShooter and thanks a lot to all helpers.
I fixed it for a little bit. Now close focus is at near 0.53 m but not at 0,45.
For me itīs okay and I decided to use it like this. Maybe I fix it later but I think Itīs okay for me to have 10cm lost.
Here are some more examples
1) F1.2_at infinity
2) F4_at infinity
3) F1.2_at infinity
4) close focus (about 55cm) @ F1.2
5) close focus (about 55cm) @ F2
6) close focus (about 55cm) @ F2.8
7) close focus (about 55cm) @ F4
8) close focus (about 55cm) @ F5.6
PENTAX K-3  Photo
PENTAX K-3  Photo
PENTAX K-3  Photo
PENTAX K-3  Photo
PENTAX K-3  Photo
PENTAX K-3  Photo
PENTAX K-3  Photo
PENTAX K-3  Photo
07-16-2016, 01:25 PM   #21
Are you sure you have the element back in the proper order? I looks really out of focus
10-11-2019, 03:56 PM   #22
Hi,
I'm might come in too late!
That item 2 in the picture of post #7 consists of two parts: the focusing ring and a part of the barrel. These two parts are screwed together with a very fine thread, making the focus ring rotating. My guess is that you should try to unscrew the focus ring one or two turns, before putting the stop screw for close and infinite focus. Then insert the lens elements block at the right angle and fix the two clamps that prevent the lens element block to turn freely.
Never disassembled the 1.2, but this focusing mechanism is universal in Pentax lenses.
Hope this helps!
Regards,
Wim van Heugten
---------- Post added 10-11-19 at 04:00 PM ----------
One thing more: that's left handed thread, so you unscrew it while turning it clockwise!
Wim
50mm, assambling, assemble, base, block, data, dissamble, dissambling, f1.2, focus, fotos, help, information, lens, lot, pentax k, pentax service, positions, post, repair, service, settings, thread, warranty
Help : problem with the SMC Takumar 50mm f1.4 redcat Pentax SLR Lens Discussion 11 06-09-2015 12:33 AM
Pentax M 50mm f1.7 Disassembly - Assembly jaitas Pentax SLR Lens Discussion 8 08-22-2014 09:16 PM
50mm f1.2 smc M lens with dslr help rozzercass Troubleshooting and Beginner Help 3 03-01-2013 11:26 AM
HELP - F-- Error (Blinking) with new SMC Pentax-M 50mm F1.7 IanAntonio Pentax K-5 6 10-18-2012 01:39 PM
Need help with exposure problems and snow photography problems, urgent please respond montezuma Photographic Technique 7 02-24-2008 05:43 PM
All times are GMT -7. The time now is 01:57 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
