Originally posted by Senseriffic I am sending a lens in to get repaired, but I also have an issue with my K5, it jumps shutter speed when Im changing it with the dial. It doesn't always do it but it does it often enough that I cant really use it in manual mode. I tried cleaning it which worked temporarily. Any suggestions? Should I send it in or repair locally?
Does this happen in TAv mode also or only M mode?
Can you use Av mode and exposure compensation to get your exposure the way you want - it's not as direct but you can "back into" the exposure multiple ways.
